Discussing tranny problems in the 5.0 Mustangs Forum. Ihave a 86 fox body with a 87 motor and tranny when i replaced the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
tranny problems
Ihave a 86 fox body with a 87 motor and tranny when i replaced the clutch and go to put the trans back in it will not go all the way in about another inch is all i need to bolt it back in place can some one help me please
did u adjust the input shaft so it slides in the right way? Readjust thetranny and see if thats it
yes i did . i even rocked the trans with no hope i used the alignment tool and can see in the bell housing and it appears straight . the motor couldn't have dropped could it?
1983 GT
UNKNOWN
did you slide the friction plate onto the input shaft before you bolted the cluth to your flywheel??? 9 times out of 10 it the right clutch but theres still that possibilitie you got the wrong one. happened to me at work before so you never know
1983 FOX BODY-LIL SOMTHIN IN PROGRESS |
no i didn't but i will pull all back off and do that though thank you didn't think of that
did it work?
(2000 v6)bbk cai,motoblue udp,65mm throttlebody+spacer,diablo tuner, 4.10 gear,t-lok,160 thermostat, screamin demon, msd wires. bbk shorty headers, off road x,streetpro mufflers, Royal purple fluids, K&n oil filter. (89 5.0) msd dist,wires |
You should jack up the engine a bit, then slide the tranny back in. That should take care of it. i bet the engine dropped a bit like u said
Had a similar problem with getting the nose of the input shaft into the pilot bearing, I just started the bolts and slowly cranked them in evenly, and it went in. That was in September and haven't had any problems.
#9 | |
1990 LX hatch
Asshole™
1990 Mustang LX
9.36@143 mph
Put the trans in as far as you can get it. Then have someone push the clutch in while you wiggle the trans. It will slide right in as long as the input shaft splines are somewhat lined up. I've done this several thousand times. I also use a yoke off of a stock drive shaft. I stick it on the output shaft so I can turn the input shaft to line the splines up easier.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
Thanks guys for the help!!!!!! i will try some of these things in the morning one way or the other i should be rolling again tomorrow will let you all know the outcome and once again thanks........i'm not a mechanic by no means just trying to save the all mighty dollar
Threads Similar to: tranny problems
| Tranny problems | jtlogruss08 | V6 Mustangs | 2 | October 16th, 2007 02:19 PM |
| Tranny Problems | mustangman03 | Drivetrain | 6 | September 9th, 2007 10:42 PM |
| Tranny problems?? | 03_StangGuy | 99-04 | 9 | July 4th, 2007 07:48 PM |
| more tranny problems | marks87gt | Drivetrain | 3 | April 12th, 2007 12:07 AM |
| Tranny Problems... | Frog's_Stang | 5.0 Mustangs | 2 | October 25th, 2006 09:27 AM |
