New Motor
Old July 16th, 2009, 07:05 PM   #1
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
HOLLYWD69 is on a distinguished road
New Motor
I just bought an 86 GT for my son. We want to do a motor swap nothing crazy just a little more power, something we can work on together. I know the speed density limits the power so I am going to do a mass air conversion. I am looking at a late 90s explorer motor, do a cam swap and some port a polishing on the heads and the intake and drop it in. My question is do the crown vics or the trucks have the same motor as the explorers? I haven’t been able to find a 5.0 explorer at any of the junk yards around here. I want to pull it myself so I can get the mass air meter and all of the accessories and it’s a lot cheaper to pull it yourself at a junk yard than to buy one on line. Plus that would be something we can do together also. Thanks for any help.
07GT/CS, GTA exhaust, FRPP handling kit, Whipple SC, Hurst shifter, Roush Gauge Pod, Glow Shift A/F & Boost gauge, J&M adjustable panhard bar, LCA & relocation brackets, UMI adjustable UCA, Shaft Masters Alum. DS, Pacesetter LT headers & OR H-pipe.
Old July 16th, 2009, 07:17 PM   #2
13.64@101mph
best bet is find a 5.0 mass air setup out of a mustang, all you want off the explorer is the upper and lower intake, heads and throttle body. and the 5.0 in all other ford, lincolns are stock foxbody stuff
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old July 16th, 2009, 07:17 PM   #3
1998 Cobra
13.24@105.66
I think your on the right track here. Lots of guys are going fast with simple gt40 setups.
Gt40 with a decent intake, full exhaust and a set of a slicks will make for a hell of a ride
weeee foooord!
Old July 16th, 2009, 07:20 PM   #4
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
Are the late 90s motors better than the early 90s or pretty much the same?
Old July 16th, 2009, 07:29 PM   #5
1998 Cobra
13.24@105.66
87-92 Mustang motors were forged with deep valve reliefs
Early Explorers Came with GT40 heads (Cobra) (non -p's) and cast pistons
Late Explorers came with GT40P heads and cast pistons..
P heads are cool because they give a little compression bump.
Ideally the best setup would be an 87-92 short block, some p heads, stock cam and 1.7rr's. Would be cheap but has been proven to perform.
I'll wait for Mustank to chime in.. He took his P headed combo into the 11s
weeee foooord!
Old July 16th, 2009, 07:37 PM   #6
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
Cool thanks for the help.
Old July 16th, 2009, 07:47 PM   #7
13.64@101mph
i think the 5.0 wasnt dumped into the explorer til about 96ish. first couple years had gt40 (93 cobra) heads, then until the 4.6 crap they had gt40p's w/ different angled plugs so most headers wont work with them
Old July 16th, 2009, 08:06 PM   #8
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
So no GT40p heads then.
Old July 16th, 2009, 08:08 PM   #9
13.64@101mph
some have luck w/ bbk headers, some w/ stock ones and i know MAC LT's work
Old July 16th, 2009, 08:10 PM   #10
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
Cool thanks for all the help.
Old July 16th, 2009, 08:32 PM   #11
1998 Cobra
13.24@105.66
why not? Ford Racing sells p specific headers
weeee foooord!
Old July 16th, 2009, 08:33 PM   #12
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
[QUOTE=superbean;2192108]why not? Ford Racing sells p specific headers[/QUOT
cool thanks. thats why I ask.
Old July 16th, 2009, 11:32 PM   #13
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
FRPP Shorties work with P heads...
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old July 16th, 2009, 11:56 PM   #14
1998 Cobra
13.24@105.66
That's because the p50 model headers were designed to work with angled plugs and straight plugs like the gt40p...
weeee foooord!
Old July 17th, 2009, 01:48 AM   #15
A junk yard exploder block would be good for you...dont wast money with porting... depending on how much you drop on the block...... Depends how much money you have? Depends how fast you wanna go....everything depends...
Example on my build / cheap slap together.....
89 stock short block....100.00
afm n41 cam ..........100.00
Gt40 p heads fresh from machine shop/fresh resurface/new valves/valve job/Comp dual spring/yada yada still stock pedestal mount..............400.00
Exploder intake/pulled from a junk yard......60.00
pp 65mm tb 50.00
Rest was all there....Full exhaust/gears/19lb injectors/stock suspension/etc etc....Springs were miles off and not set up....
I personally got the car to run 11.9's.....trust me it shouldnt have but I made it.Not many will so this...its not hard....but it does take time....aka 50 passes down the axis road before the track lol........
I have learned a lot from all my experiences.....The stock ones are fun......Playin cheap is fun until you get tired of breaking stuff or going slow.
PeteAndersonRacing.com
Old July 17th, 2009, 06:32 AM   #16
87 Mustang GT T-top
The Novice is on a distinguished road
Hey mustank, when you ran the 11.9 you were on slicks correct?
Thats a pretty nice time and a money saver, nicely done!
Old July 17th, 2009, 08:18 AM   #17
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
pp 65mm tb 50.00
I'm not looking to make a ton of power, about 325hp would be good. I wouldn't spend any money porting just some back yard port and polish and gasket matching by myself. Its been a while since I have done any engine work and never with fuel injection so all the help is appreciated.
Old July 17th, 2009, 04:39 PM   #18
95StangMX's Avatar
95 Mustang GT
325 is going to cost you a little more than you think. Is that goal to the wheels or the crank?
Old July 17th, 2009, 05:07 PM   #19
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
At the crank
Old July 17th, 2009, 07:02 PM   #20
1998 Cobra
13.24@105.66
280 whp, 320chp is very easy to attain using a gt40p headed car.
remember, horsepower isn't everything.. having a car that can put the power down and a driver to use the power > dyno sheets
weeee foooord!
Threads Similar to: New Motor
2000 v6 motor change to explorer 4.0 motor v6must742 V6 Mustangs 29 May 25th, 2009 06:03 PM
How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? Jonathan General Tech 3 January 2nd, 2008 10:34 PM
How do you find the motor code on a 88 5.0L motor? semihemi428 5.0 Mustangs 1 March 16th, 2007 05:56 PM
