Fuel pressure and timing needed for mods?
Old July 17th, 2009, 06:12 PM   #1
5.0 street stanger is on a distinguished road
I need to know what fuel pressure and timing I will need for my new setup. So the list of mods are. GT-40P heads with a 3 angle valve job, GT-40 upper and lower, and the 65mm (I believe it is 65mm) that came from the explorer, 80mm mass air, 24# fuel injectors, MSD cap and MSD blaster coil, Accell wires, Cold air intake, Summit longtube headers, H pipe, 2 1/2 dual exhaust going into two Flowmaster super 40 series mufflers, A/C delete, Electric fan, Smog pump delete. So i need to know what to set the timing at. Right now the timing is set at 14 degrees retarded. I dont have a adj. FPR right now. I planning on getting a fuel rail off an explorer or 94 up mustang cause there FPR is two bolt instead of 3 bolt like my stock on is. Reason I want to do that is because Im not using the GT-40 elbow nor am i useing the EGR plate. I made a bracket for the throttle linkage and it will work but part of the linkage hits the FPR on the 3rd bolt that sticks out towards the linkage. I dont think I will have this problem with the 2 bolt FPR. What about gapping the plugs? Stock gap? What are the best plugs to use?
Old July 17th, 2009, 08:47 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
There is no magic timing and fuel pressure specs, its whatever the engine likes. I'd start with about 36lbs of fuel pressure and timing at 15-16* BTDC.
Old July 19th, 2009, 06:13 PM   #3
sweet, Ill start with that. thanks
Old July 20th, 2009, 01:30 AM   #4
2003 mustang GT
bishop805 is on a distinguished road
heeloo
Old July 20th, 2009, 01:30 AM   #5
2003 mustang GT
ok sorry
Threads Similar to: Fuel pressure and timing needed for mods?
Fuel pressure and timing nasty92LX 5.0 Mustangs 12 March 19th, 2008 04:44 PM
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 12:41 PM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 07:58 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 04:31 PM
Timing and Fuel Pressure Vamp89 5.0 Mustangs 1 July 25th, 2006 09:16 PM
