help need boost!
'89 gt s-trim vortech 480 whp 13 lbs. boost. i deleted my smog pump and pulley. i lost boost. what could be the cause vac. line, back pressure, air tube to heads. HELP?
490whp/432wtq, V2 13lbs. boost, 3.33 pulley |
could anything from the delete affect boost pressure?
did you replace the pulley with a delete pulley, or opt for a shorter belt?
1993 5.ohhhh
12.97 @140mph
I think you need to look elsewere for the problem. That shouldn't have an affect on your vortech pushing posative pressure into the motor.
btw whats your setup?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1986 mustang gt
go back and recheck ur installation, make u conncected all ur lines. the delete shouldnt have affected ur supercharger
1992 Lx
11.39@119.24
im guessin belt slip from using the wrong sized belt
1993 5.ohhhh
12.97 @140mph
Short belt shouldn't affect the blower either, they run off differn't pulleys.
im going to go with belt slippage..
1994 Ford Mustang GT
well like stated before it runs off a completely different belt, besides that im pretty sure he could figure out the be slipping... like not making boost past a certain point and hearing a loud squeel, id check your lines and everything, im not really sure to be completely honest
www.moddedmustangs.com |
i went with a shorter belt. there were only two vac. lines which i traced to the vac. block on pass. side fenderwell and plugged them. thanks for the replies. i will go over intake and vac. system. was just seeing if anyone could possibly avoid the madness.
Threads Similar to: help need boost!
| Boost | Blown2000GT | General Tech | 4 | August 27th, 2009 03:35 PM |
| how much boost?? | dudelinger | 4V / SVT | 11 | March 1st, 2009 09:21 PM |
| how much boost with no IC | 20gtvert03 | 99-04 | 10 | June 29th, 2008 07:39 PM |
| boost??? | 2001bullitt | 99-04 | 3 | April 26th, 2007 04:41 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 10:56 AM |
