87 Mustang GT T-top
Putting the Tranny Back in tomorrow - Quick Question
Ok so i resurfaced the flywheel and got a new King Cobra Clutch kit and just rebuilt my tranny, Its a Tremec T-5z and im about to put it all back together now that i got my new Rear main seal in and everything is good to go.
3 quick questions.... 1- Whats the TQ specs for the Flywheel and clutch? 2-What ATF should i use or will work best? Dextron? Napa brand? Or does it not matter really? 3- How many Quarts of Tranny Fluid Do i need for my T-5z? And also the big question is how do i get it all in there? The Whole is on the side of the trans, but i cant put it all in 1st before i lift the trans to line it up b/c of the driveshaft hole will spill it onto the floor...and tricks or ideas of how to do this the easy way? Thanks for the help guys, never done this before so any tips and info help! So thank you very much guys! - Joe. |
1991 mustang 5.0
Dex/merc ATF. 2.8 or 2.9 quarts. I put mine in through the shifter base.
1986 LX
none yet
you can fill through the shifter or you can use a siphon pump that you can pick up at most auto parts stores. fill it until the fluid starts coming out of the top hole.
87 Mustang GT T-top
Oh ok got it, ill have to try that. Also it wont mess up the shift forks or anything will it? I just want to make sure they line up correctly when im done.
Thanks for the help! And does anyone know the flywheel TQ specs? |
Proud American
75-80 foot pounds, or 65 if you are using arp bolts. Also make sure to use a moly lube.
87 Mustang GT T-top
Ok i took off the shifter and the boot any everything, and now that part of the tranny is all open. My question now is do i have to take out the Center column? The rubber boot any everything is in the way, and i wont be able to get the shifter and boot any everything back together b/c the hole isnt big enough.
1991 mustang 5.0
I took out the whole center console, shifter, boot, everything so all you will have is carpet and you can see the tranny. Just slowly pour it in.
Threads Similar to: Putting the Tranny Back in tomorrow - Quick Question
| SCT X3 question (Need a quick answer by tomorrow AM) | Odin | 2005 - 2010 | 11 | June 23rd, 2009 01:27 PM |
| quick tranny question | M0T0PSYC0 | 99-04 | 1 | April 8th, 2009 03:30 PM |
| Quick Tranny Question... | ShapeShifter | 99-04 | 4 | October 23rd, 2008 06:47 PM |
| going to emissions tomorrow quick question | e3sean | 5.0 Mustangs | 3 | May 8th, 2008 10:03 PM |
| putting the heads/intake back on tomorrow | Devine | 5.0 Mustangs | 8 | January 18th, 2008 03:10 PM |
