Is this ok?
Old July 19th, 2009, 01:21 PM   #1
joedaddy4's Avatar
1994 Mustang GT
joedaddy4 is on a distinguished road
Is this ok?
Ok I have to replace my piston rings in my 94 gt I have a set of pistons I belive that are out of an 87 and they r stock forged now would it be ok to put the forged pistons out of the 87 in my 94 block? I don't think there is any difference? Since I have to replce rings anyways. Thanx
1994 GT 5.0, 302 c.i. studded and girdle, Cobra upper and lower, gt40p heads, 3.73 gears and stock T-5, boostbrothers turbo kit, master-power t70 turbo, pro-m mass air, 80# injectors, manual rack, tubular k-member, a-arms, upper & lower control arms
Old July 19th, 2009, 01:35 PM   #2
The Razor's Edge
White Thunder's Avatar
is it just the pistons or do you have a entire rotating assembly?
founder of the FTN Club
Old July 20th, 2009, 09:15 AM   #3
joedaddy4's Avatar
1994 Mustang GT
pistons and rods
Old July 20th, 2009, 12:10 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No it is not ok. Forged pistons require more clearance than hypereutectic pistons. You would have to at least measure clearance and increase the clearance accordingly. It would all be a waste of time because you would see no benefit to swapping to a set of forged pistons. If anything it will hurt because the factory forged pistons are so heavy.
Why do you have to replace the rings?
Old July 20th, 2009, 01:30 PM   #5
joedaddy4's Avatar
1994 Mustang GT
i have an extreme case of blowby i am doing a compression check after work today to verify but thats just my thoughts that i either cracked a piston or fried the rings not a hundred percent sure but somehow i am getting alot of pressure built up in the oil pan causing oil to come out of the dipstick tube
