Discussing car wont idle in the 5.0 Mustangs Forum. i put a 302 in my 4cyl mustang. i have the new comp. and v8 ...
Old February 2nd, 2007, 05:24 PM   #1
car wont idle
i have the new comp. and v8 harness..
the problem is when i first start the car up it idles for a few seconds and then shuts off. i start it up a couple more times and it still does it. but after 4 or 5 times of starting and shutting off. it will start and run fine... then when i step on the gas it hesistates..
Old February 2nd, 2007, 07:03 PM   #2
change the throttle body and egr gaskets along with the iac gasket...u should be fine as long as u dont have any intake leaks.. also check the timing..
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old February 2nd, 2007, 07:13 PM   #3
shurb125's Avatar
1993 Mustang LX Vert
I had somewhat same problem all last week check out these links (93 running horribly and computer or maf problem.These are the responses I received and finally shes running strong a week later, just be patient and good luck
These are the links but I don't know if they will work:
http://www.moddedmustangs.com/forums...m-vt13176.html
http://www.moddedmustangs.com/forums...y-vt13881.html
Threads Similar to: car wont idle
Wont be on MM as much.... TurboLX The Clubhouse 30 July 25th, 2007 03:25 PM
Wont Hold Idle When Warm zero 5.0 Mustangs 22 March 17th, 2007 12:39 AM
idle wont drop..Any Ideas superunknown23 V6 Mustangs 7 February 22nd, 2007 03:38 AM
damn thing wont idle 99modular 99-04 2 November 22nd, 2006 08:46 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 05:11 AM
