331 build
Old July 20th, 2009, 08:11 PM   #1
1988 Mustang
88Saleen is on a distinguished road
Send a message via AIM to 88Saleen
331 build
hey guys i havent been on recently due to the depressing fact that my car is broke latley and i have no money to work on it. Well great news came and i am receiving 6k over the next 6 months. I have plans and list of parts, trying to budget the money so that i can get a decent build all throughout my car.
Current Build
Head/cam/intake combo by edlebrock
Fuel press. reg
24lb injectors
74mm MAF calibrated to 24lb injectors
75mm TB and spacer
CAI
BBK shorty headers
off road h-pipe
smog delete
EGR delete
1.7 rockers
Stock trans
stock suspension
stock tires/wheels
Engine plans
331 stroker kit
around 10.5:1 compression
use of the topend kit and possibly same cam, depends on how far the money goes
high vol. oil pump
255lph fuel pump
Chassis/suspension
full sub frame connectors
8pt cage
50/50 shocks out back
70/30 struts up front
adjusable upper and lower control arms in rear
Trans/rear end
shift kit install
rebuild bands and clutch packs with HP kit
custom TQ converter
hardened axles
Im building a n/a motor. i knwo i wont get the most power, but i figure if i can build 400 with this build and hook up i will be well into the 11's. I dont want much more than 400 due to the strength of the stock block, i dont want to worry about it blowing. What do you guys think? am i real far off for a decent build all around?
Old July 20th, 2009, 08:25 PM   #2
Mean 5.0's Avatar
1990 Ford Mustang GT
12.0 @ 116
Mean 5.0 is on a distinguished road
Look at the thread 331 horsepower capability, might answer some questions...i made 318RWHP & 345RWTQ and ran 12.6 @ 111 on a baby launch, IF you can make 400 HP you should be well into the 11's, easy way to do that is a quick hit of nitrous...
Old July 20th, 2009, 08:38 PM   #3
1988 Mustang
yeah i read that i think i responded once, and i think that your numbers are a tad on the low side, right now i run a 13.4 @ 104 with a 2.2 60 foot and loose in second with my current build.. idk what your doing, but seems like you should be building higher numbers and running faster ET's. im staying n/a
Old July 20th, 2009, 08:48 PM   #4
1992 Lx
11.39@119.24
get some real heads
Old July 20th, 2009, 08:53 PM   #5
1988 Mustang
Originally Posted by 93hatch View Post
get some real heads
yeah, i have thought about that, i dont want to run out of money. im sure once i sell a lot of the stuff im taking out it will be more of a possibility. which heads would you suggest? twisted wedge?
Old July 20th, 2009, 08:55 PM   #6
1992 Lx
11.39@119.24
if you might run outa money, do the top end you plan on running on the 331 to your lil 302 now, then when you get more money, buy a stroker shortblock from woody. That way you have a fast car now but itll be even faster with the 347 stroker kit your gona buy
Old July 20th, 2009, 08:55 PM   #7
1992 Lx
11.39@119.24
and i say get some canfields
Old July 20th, 2009, 09:48 PM   #8
95StangMX's Avatar
95 Mustang GT
I say twisted wedge and 347
Old July 20th, 2009, 10:13 PM   #9
1988 Mustang
im sticking with the 331. i will have to try and come up with the money for a good set of heads
Old July 21st, 2009, 12:04 AM   #10
Why 331?
PeteAndersonRacing.com
Old July 21st, 2009, 01:23 AM   #11
1998 Cobra
13.24@105.66
302 parts make 302 power..........
But... those edelbrock heads will still run leaps and bounds over a stock head lol.
Rather small on a 331+ cubic inch motor.
Go 347, extra cubes help.
weeee foooord!
Old July 21st, 2009, 10:41 AM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Engine plans
331 stroker kit
high vol. oil pump
255lph fuel pump
That combination sucks. You would be better off sticking the money into a set of good heads, cam and intake for your 302. It would be much faster than a 331 using the Edelbrock kit that you have now. Skip the high volume oil pump too. I'd also being doing a 347 if I was stroking it. The price is about the same.
Old July 21st, 2009, 02:50 PM   #13
95StangMX's Avatar
95 Mustang GT
Oh boy I can see it coming ....... I am going with the 331 because my friend said they last longer and the ratio , and wristpin....blah blah blah
Old July 21st, 2009, 07:31 PM   #14
1988 Mustang
im going with a 331 for that reason yes.. not just my friend, but lots of guys i have hurd. i dont wanna argue about it honestly, so if we could stay away from that repetitive bull that would be great. i would rather stay on the topic of how the build that "I" want to do sounds. if your just going to knock it idk why im on this forum. I am going to get Trick Flow twisted wedge heads for it, going to try and find a better intake if possible also.
Old July 21st, 2009, 07:32 PM   #15
1988 Mustang
why skip the pump?
Old July 21st, 2009, 07:48 PM   #16
Is this a fairy tail build? ....Thinking out loud?
How much is in you savings?
Old July 21st, 2009, 07:52 PM   #17
1988 Mustang
again i dont understand the smart ass comments? i dont understand how it is a fairy tail build.. i have 6k and how ever much i get out of selling the stuff i have that im replacing. i mean if its going to keep going back to how i need to do a 347 and how its a fairy tail build, thats fine i will go else where.
Old July 21st, 2009, 08:19 PM   #18
JBIGBOOTSY's Avatar
1990 LX hatch
Ahhh the 16ci debate....
Old July 21st, 2009, 08:34 PM   #19
6k in 6 months? Just had a kid and gettin welfare?
Old July 21st, 2009, 08:40 PM   #20
1988 Mustang
haha naw... student loans. i get a refund check every 6 weeks.
Threads Similar to: 331 build
331 build pitbkr08 5.0 Mustangs 10 December 20th, 2008 03:57 PM
Need advice on 331 build foxstang 5.0 Mustangs 36 December 9th, 2008 01:40 PM
What do you boys think of my 331 build so far? cybertech 5.0 Mustangs 20 September 10th, 2008 02:17 PM
How to build a 331 stroker Drick 5.0 Mustangs 10 January 25th, 2008 08:57 PM
Gonna build a 331 w TF Track kit... LazerRed_91_LX_5.0 5.0 Mustangs 2 July 29th, 2006 06:40 PM
