alternator for electric fans
switching to two i believe 12 inch electric fans and a better radio system (video/nav deck)
will a 100amp alternator be sufficient or do i need to go 140 or even 3g ? anyone using one of these kits or have heard anything about these kits 86-93 5.0L MUSTANG COMPLETE RADIATOR UPGRADE KIT FOR MANUAL TRANSMISSION MUSTANG also, thinking about switching to a electric water pump, would like to get one less pulley on my belt and like the minimal look
if you were on a bicycle and we were going up hill i could beat you in a race Last edited by stfudvs; July 21st, 2009 at 09:05 PM. |
Priest of the Car Gods
the better deck shouldn't draw that much more power than the stock unit (assuming you're not running an amp), and the fans shouldn't be on that often (especially in Reno).
I would think that so long as you don't have UDPs, the 100amp should be fine.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
i will have udp's and the electric water pump, i should be good with 100 ?
yea reno weather is great
if you were on a bicycle and we were going up hill i could beat you in a race |
I would go with a 130 amp setup..
weeee foooord!
#5 | |
My very unfounded suggestion would be to bump up to the 140.
88 mustang GT
go for a 3g i picked mine up for 35$ at a junkyard and about 30 bucks in wiring(went to a expensive car audio shop for it)
1986 LX
none yet
+1 3g runs my two electric fans. No stereo or electric water pump though. Depending on what kind of fans you use that will make the biggest difference on what amperage you need. the water pump shouldn't pull much and the stereo hardly any at all. If you run an amp then just ad a good 5 farad capacitor and that will keep up with your stereo without killing the car
1987 ford mustang gt
well see when shes done
Most electric water pumps only draw around 10 amps.. Some such as csr pumps only draw like 6
88 mustang GT
my 3g runs my fans 300w and 125wx2 amps and stays well above 12v all the time
#10 | |
Go with a 3G. Easy upgrade.
that settles that
3g it is thank you gentlemen
Threads Similar to: alternator for electric fans
| electric fans | stfudvs | 5.0 Mustangs | 29 | February 21st, 2009 03:34 AM |
| electric fans | mxnate116 | 5.0 Mustangs | 7 | June 12th, 2008 12:01 AM |
| Electric Fans... | DIRTYD | 5.0 Mustangs | 12 | December 22nd, 2007 09:40 PM |
| eLECTRIC faNS | javier351lx | 5.0 Mustangs | 30 | September 13th, 2007 10:03 PM |
| Electric Fans | javier351lx | 5.0 Mustangs | 15 | July 15th, 2007 03:10 PM |
