Discussing aod to c4 automatic conversion in the 5.0 Mustangs Forum. I have a 1990 coupe v8 it had an aod in it that went out ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
I have a 1990 coupe v8 it had an aod in it that went out and I converted it to a c4 and I am having a ton of problems. I had to change the fly wheel so that my tourque converter would bolt up and now when you turn the key the car will not start. the starter will spin when you jumper it but it will not work by the key. it sounds if the starter is not touching the fly wheel. can some one help
Thank you Kindly |
Zippee is my step sister.
1990 Mustang LX
9.36@143 mph
Sounds like you have a 157 tooth flywheel and a 164 tooth bellhousing.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft My daily driver has 16 cylinders and 4400hp @ 1000 rpm....
did you put the dust plate back on? (thin plate in between bell and motor) if not then you will likely have the wrong spacing and your starter will not engage with the starter. i think darrell is right though. since you have to change flexplates, you have to change bell housings
1990 Mustang LX
9.36@143 mph
The AOD flexplate should have worked. You must have got the wrong converter. There are a couple variations with C4 converters. I use AOD flexplates on all of my 5 liter 50 oz C4 conversions.
Threads Similar to: aod to c4 automatic conversion
| AOD TO T5 CONVERSION... | 173speed | 5.0 Mustangs | 3 | April 10th, 2009 10:32 PM |
| 5spd to AOD conversion | r.barn | 5.0 Mustangs | 10 | August 29th, 2008 10:49 PM |
| Automatic To Manual Conversion | man_of_war2081 | 99-04 | 6 | November 17th, 2007 03:59 PM |
| AOD to T-5 Conversion | IcantDo55 | 5.0 Mustangs | 7 | June 14th, 2007 11:03 PM |
| AOD to T5 conversion | 5chargedliters | 5.0 Mustangs | 2 | November 11th, 2006 11:43 PM |
