car wont start
LinkBack (1) Thread Tools
Old July 21st, 2009, 11:44 PM   1 links from elsewhere to this Post. Click to view. #1
87gtmustang's Avatar
1987 mustang GT
87gtmustang is on a distinguished road
Send a message via MSN to 87gtmustang
car wont start
i finally got the car all put back together and it wont start. itll turn over and act like it wants to start but it wont. all the spark plugs are getting spark and it smells like its getting gas. i got two tubes on the back of the upper intake that i dont know what hooks up to mayb thatll change y it wont start.
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump
and more to come
Old July 22nd, 2009, 12:22 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
What was taken apart? Did you have the distributor out? Did you have the spark plug wires off?
Old July 22nd, 2009, 12:32 AM   #3
1987 mustang GT
yes to both but i pulled the heads off. i put the distributor off but i put it wright back where it was when i pulled it and the sparks plugs in the same place.
and more to come
Old July 22nd, 2009, 03:22 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You might want to double check the firing order and verify that the distributor is phased correctly. I'm willing to bet your problem is related to the distributor and/or firing order.
Old July 22nd, 2009, 09:44 AM   #5
1987 mustang GT
ya i checked the firing order like 5 times
and more to come
Old July 22nd, 2009, 10:54 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
And its wired 1-3-7-2-6-5-4-8 and run counter clockwise on the distributor?
If so you need to verify the distributor is in correctly and get #1 cylinder to TDC on the compression stroke.
Old July 22nd, 2009, 11:26 AM   #7
1987 mustang GT
thats for the ho 5.0 tho i tried that order and the order 1542678
and tdc whats that
and more to come
Old July 22nd, 2009, 11:56 AM   #8
t70
t70's Avatar
2000 GT CONVERTIBLE
t70 is on a distinguished road
and tdc whats that
pull the number 1 sparkplug and turn the engine by hand with your finger sealing the plug hole til you feel the pressure push against your finger, thats the compression stroke.
look in or feel inside with something and while still turning the motor by hand watch for the piston to come up as far as its going to thats top dead center on # 1
put distributor in the engine while keeping the rotor pointed to the # 1 terminal ( you can just make a mark on the body of the dist even with the #1 terminal
it may move a bit off the mark as you put it in when the gears mesh but that should get you in phase. now you'll still have to get the timing set when its running
if you want to search the technique to find pics it's called dead timing the engine
good luck
silvermustangsregistry#0711
Old July 22nd, 2009, 01:02 PM   #9
1987 mustang GT
got the car started it wont start all the time but we gotta mess with the distributor and pull off the cold air. but it still aint running just right. try to give it any gas it dies
and more to come
Old July 22nd, 2009, 01:14 PM   #10
1998 Cobra
13.24@105.66
timing problem eh
weeee foooord!
Old July 22nd, 2009, 01:24 PM   #11
1992 Lx
11.39@119.24
timing/firing order is fucked up. And plug those extra vacuum lines coming off of the intake
Old July 22nd, 2009, 01:32 PM   #12
1992 Lx
11.39@119.24
youre also missing a nut on that top bolt, do you have all of the nuts on? including the one inside the intake behind the cover?
Old July 22nd, 2009, 02:34 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Timing is retarded.
Good catch. That is a major vacuum leak there.
Old July 23rd, 2009, 03:26 PM   #14
1987 mustang GT
ya i figured where one line went for sure and what sucks is i got it runnin about ten mins before i had to go to work and i gotta go back and tighten down the rocker arms
and more to come
Old July 25th, 2009, 01:58 PM   #15
1987 mustang GT
pluged all the vacume leaks. i figured out by looking at pics that the rotor on the distributor was a little wrong it spun very little to the right when installing but it cranks up and idles fine still needs to mess with the timming a little
and more to come
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/131036-car-wont-start.html
Firing Order on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback July 24th, 2009 02:51 AM
Threads Similar to: car wont start
car wont start krispy V6 Mustangs 3 July 1st, 2008 07:17 AM
Car Wont Start? Trent-04v6 Audio/Video 8 February 20th, 2008 12:26 PM
Car wont start!?!? SantanielloITA V6 Mustangs 70 November 7th, 2007 04:24 PM
car wont start 2007calispecial Modular Mustangs 4 May 18th, 2007 09:05 AM
Need Some Help - Car Wont Start ANoXiA 2005 - 2010 6 December 23rd, 2006 06:07 PM
