fog light ram air
Old July 22nd, 2009, 01:57 AM   #1
stfudvs's Avatar
302 5.0
stfudvs is on a distinguished road
fog light ram air
anyone doing this, was thinking about it instead of a wheel well filter
if you were on a bicycle and we were going up hill i could beat you in a race
Old July 22nd, 2009, 09:48 AM   #2
stfudvs's Avatar
302 5.0
no i have heard of people using ducting that runs from the filter down to the fog light, then using mesh screen over the fog light, just wondering if it would be restrictive when not driving at high speeds
Old July 22nd, 2009, 09:51 AM   #3
baine21225's Avatar
fenderwell will work better, the fog light is a longer distance with more bends
Old July 22nd, 2009, 11:05 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've done it with dryer ducting on a few GTs. I believe the size is 6".
Old July 22nd, 2009, 12:41 PM   #5
stfudvs's Avatar
302 5.0
yes i found a write up online how to make it with dryer ducting
my questions is the por and con
fenderwall seems like the filter will be less restricted because its not inside of a enclosed cylinder, but here in reno i would be kicking up a lot of crap all over my filter
the ram air seems like a good idea but will it hurt the air flow because the filter is inside an enclosed cylinder, will it pull good air when im not on the freeway
Old July 22nd, 2009, 12:55 PM   #6
1998 Cobra
13.24@105.66
Just be careful mounting your filter down that low. Driving in a down pour could end up bad..
weeee foooord!
Old July 22nd, 2009, 01:01 PM   #7
stfudvs's Avatar
302 5.0
well i want to leave my filter were it is now, in the engine bay, but build a cone arriound it using dryer ducting that leads down to the fog light
Google Image Result for http://www.mikefordmustang.com/writeups/how-to-make-a-rear-seat-delete-mustang/rear-seat-delete_files/rear-seat-delete-diy-thumb.jpg
Old July 22nd, 2009, 01:16 PM   #8
1998 Cobra
13.24@105.66
Oh I got ya. I bet it would help cruising down the highway
weeee foooord!
Old July 22nd, 2009, 02:36 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Use the flexible tubing, not that stuff in the pictures. You will be glad you did.
Old July 22nd, 2009, 03:35 PM   #10
nolife's Avatar
91GT, 88GT, 02GT
I did one with the flexible aluminum drier duct years ago on my stock GT. It did not help my 1/4 time or speed at all but the car was completely stock including the paper air filter so maybe that's why. I did notice that the duct was great at picking up bugs, leaves, and cigarette buts though.
Old July 22nd, 2009, 03:44 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I only gained a little over a tenth but I picked up a bit over 2 mph. Stock engine with minor bolt ons. I never had an issue picking up debris though. Bugs, yes. Leaves and cigarette buts, no. I still used an air filter too.
Old July 22nd, 2009, 05:17 PM   #12
stfudvs's Avatar
302 5.0
well i will still use my k&n
im going to give it a shot and see
Old July 22nd, 2009, 07:00 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I used the stock air box with a K&N panel filter. With an open filter you will just be wasting your time. You need it to be sealed otherwise there will be no ram air effect.
Old July 27th, 2009, 12:44 AM   #14
EscortSportage's Avatar
1989 Mustang GT 5.0
i am thinking of doing this on my fox, i was also thinking of making another one on the driver side to cool my MSD 6AL box down, make a box that surrounds the MSD box and connect the pipe to feed it fresh air...(just an idea) i should just put it inside the cabin and out of the engine bay...
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old July 27th, 2009, 02:23 AM   #15
MOTOIMPAIRED's Avatar
1990 LX Coupe
MOTOIMPAIRED is on a distinguished road
It would be better and easier to just mount it inside the cabin of the car...
Old July 27th, 2009, 10:42 AM   #16
nolife's Avatar
91GT, 88GT, 02GT
My MSD box is in the drivers fender well and has been for years without problem. I typically do not drive that car unless its nice out though so it rarely sees rain.
Old July 28th, 2009, 06:06 PM   #17
1989 Mustang GT 5.0
i wanted to install the MSD box under the dash on passenger side, but when i installed it i didnt have enough wire to run the distance, so for now i just put it on the fender where the battery use to go...
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Threads Similar to: fog light ram air
JLT Ram air or Cold air? cobravenom99 4V / SVT 14 April 20th, 2008 02:20 PM
Ram Air Shaker System vs. Cold Air Intake scxc15 V6 Mustangs 9 January 28th, 2007 01:22 PM
jlt cold air or march ram air kit with k&n jagstang96 96-98 19 January 11th, 2007 06:37 PM
