Water-pump....
I think its leaking, and i just replaced it oh say about six months ago if not longer..... always my car was running when i pulled up to my house and i looked under the car., drops of water were dropping so i popped my hood to find that there was water on my water-pump any reason why? (my water pump also had turned orangish..... it was a satin finish.)
#2 | |
im not sure where it was leaking from man i was kinda shocked but i t was on the top and it was bubbling im not sure though what happend oh my smoke or steam was coming from my vents.... and it was very freaking hot
95 Mustang GT
possibly a heater core?
![]() People should think about boarding up their glass house before starting a rock fight! |
wait my dad said something about that could it be... i was not running my heater though....
Steam from the vents prob is the heater core. The orange color is prob rust. If the water pump is bad then it will b leakin from the little weep hole under & behind where the pully is. See if any of the bolts are loose. I would just remove the pump install new gaskets with a light coat of RTV on both sides. Have fun changing that heater core.. If you dont drive the car in the cold weather just disconnect it. Dont forget to cap the inlet & outlet on the firewall unless you want whatever coolant is left in the core to go all over your motor when u hit the brakes.....lol... Prob not much in there though..
ok it was on top of my water pump and it cant be rust its brand new..... and the heater core i would have to pull my whole dash apart correct i can do that in a day i think how much is it to replace the heater core anyone know? Oh and if i disconnect it.... how do i go about doing so
Why cant it be rust? The engine block is cast iron & if you dont have the correct mixture of coolant to water then it will promote rust in the block water passages. As Far as the heater core goes & someone will correct me if I am wrong I think U do hve 2 get that dash out..
Drain the system, remove the 2 hoses that go from the heater core. Block the now open passages with rubber caps & or a bypass hose of some sort 4 the water pump.. not that hard 2 do..
well how would it be rust though... and i dont think it was leaking from the weep hole but im not 100% sure so dont quote me on that one.... So if i unplug it its not really gonna matter right
#11 | |
Like I said b4 it could be rust from the water passages in the engine block.. If it is leakin from the weep hole there will be no water on the top of the water pump. One thing that is common is if the thermostat housing is leakin it will puddle up a lot of times on top of the timing cover just behind the water pump..
you can go to the store and by a heater core bypass hose and a 5/8 to a 3/8 i think splicer to connect both hoses... the heater core itself i think costed me 30 something but went vout 2 weeks later
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump and more to come
so you bought another one and it went out or what
If u do decide to do the heater core prelube with coolant the inside of the hoses that u attach to the heater core. I have seen cores break from tryin to twist push ect a dry hose on the core..
ya it went out... started leaking about 2 weeks later. they say get it from the ford house there a lot better. but its not 3/8 its 3/4
Threads Similar to: Water-pump....
| Suggestions for an electric water pump or water pump motor. | N. Dave | 5.0 Mustangs | 4 | October 5th, 2008 08:49 PM |
| water pump? | 02gtbangstang | 99-04 | 0 | January 12th, 2008 12:53 AM |
| water pump? | 02gtbangstang | 96-98 | 0 | January 12th, 2008 12:38 AM |
| Water pump | 90Stang | 5.0 Mustangs | 13 | July 8th, 2007 04:57 PM |
| Water pump ??? | Fastback GT | Classic Mustangs | 15 | February 24th, 2007 02:37 PM |
