89mustanglx5.0
Mounting my nitrous brackets
I think Ill drill into the more solid portion of the car under the hatch area carpet. I had the brackets in before bolted just to the particle board-like stuff under the carpet. It was always not very solid. It loosened up .
So, .. I think when I take the tank out (gas) to put in a new fuel send unit Ill initiate this. Ill take long bolts and put them thru from the bottom. They will stick up thru the carpet on the inside of the hatch area. There Ill use four nuts to secure this in place. Then w the four bolts secure I can put on and off the bracket , secured there w four nuts. Im no mechanic :wink so tell me how this sounds...
looking for a mustang again.! |
all motor
92 coupe
9.94@136.40
that's fine if its what u want.
The brackets have to be secure to pass tech. There are many ways you can mount them. Just use your head and do it safely. What works really nice is to drill the holes just big enough for the bolts to fit and then weld the nuts to the hatch floor. Then you just thread the bolts thru the brackets into the nuts. It makes it easier for removal and installation.
#4 | |
89mustanglx5.0
U mean go down thru the brackets into the floor nuts right? Would I need a lock nut to make it stay?
#5 | |
Threads Similar to: Mounting my nitrous brackets
| Bumper Brackets | Zatrekaz | Visual | 1 | October 25th, 2007 01:01 AM |
| 3a seat brackets. | notsoslo5.0 | 5.0 Mustangs | 2 | July 30th, 2007 12:29 PM |
| Engine Brackets | Memory | 5.0 Mustangs | 3 | September 1st, 2006 08:54 PM |
| GT ground effects brackets | ruger | 5.0 Mustangs | 0 | August 4th, 2006 08:45 AM |
