Engine rebuild
Old July 24th, 2009, 08:26 PM   #1
Lazor05 is on a distinguished road
Engine rebuild
So this isnt an exciting rebuild but it will be for me becasue its my first project.
I have an 82 GT and I have had my eyes open for a roller motor for a while. I found one for $150 and picked it up yesterday. It ran when pulled or thats what im told and has everything but lifters. Its from a 92 mustang. It also has a mild cam but the guy didnt have any specs.
So my question is what is required to get this engine ready to be dropped into my car? I know I need to tear it down and lay new gaskets rings bearings, but what about machine work?
Also the previous owner of my car claimed that my engine is bored to a 306 and has forged pistons. Is there an easy way to check that? I would hate to have the new block bored only to find out the previous owner lied to me and I really dont have a 306.
As far as the set up I am going carb'd because thats my current set up. I have a performer 289 intake and and plan on picking up a pair of gt40 heads. What cam do you guys recommend? and a different intake?
I know I have alot of questions but im new at this stuff.
Thanks
Old July 25th, 2009, 02:21 PM   #2
bump
Old July 25th, 2009, 04:02 PM   #3
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
I'd tear it down. But that's just me i'm pretty anal
spray and pray
Old July 25th, 2009, 11:04 PM   #4
Im going to tear it down for sure. Im just new to this stuff so any advice like what is absolutely necessary when tearing an engine down and putting it back together
Old July 26th, 2009, 12:02 AM   #5
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
Get all the torque specs and use them.... New head bolts along with the obvious gaskets new timing chain and gears new oil pump
Old July 26th, 2009, 12:46 AM   #6
Pingar's Avatar
Pingar is on a distinguished road
Send a message via AIM to Pingar Send a message via MSN to Pingar Send a message via Yahoo to Pingar
Don't forget a new water pump while your in their.
Old July 26th, 2009, 12:46 AM   #7
87gtmustang's Avatar
1987 mustang GT
87gtmustang is on a distinguished road
Send a message via MSN to 87gtmustang
put the bolts in a marked bag
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump
and more to come
Old July 26th, 2009, 01:42 AM   #8
Ok thanks guys. So far my list of things is-
Gaskets
Rods
Lifters
Bearings
oil pump
timing chain- theres quite a bit of play in the current one. Can this hint to anything or is it just usual wear?
water pump
Also any suggestions on a cam and intake that complements the gt40's?
Old July 26th, 2009, 02:42 AM   #9
1992 Lx
11.39@119.24
explorer intake and stock cam
Old July 26th, 2009, 03:58 AM   #10
Well im going carb'd and the explorer intake is injected right? and would a stock cam compliment the gt40's better than an aftermarket cam? I dont have the stock cam so I will be buying one regardless
Old July 31st, 2009, 11:35 AM   #11
bump
Old July 31st, 2009, 11:40 AM   #12
1992 Lx
11.39@119.24
yes its for fi, and a stock cams better than a random cam, thats prob an e303
Old July 31st, 2009, 01:34 PM   #13
ok so I should just look for a stock cam? Can you buy those new?
Old July 31st, 2009, 01:46 PM   #14
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
I wouldn't get rods just put a set of ARP rod bolts in the factory rods, you can make a good power wiyh stock rods,use that money and buy roller rockers and the ARP engine fastener kit
"Having a 9 second neon is like coming out of the closet, everyone is shocked at first, but in the end you're still gay."
5.4 Shelby Crew member #1
Old July 31st, 2009, 01:48 PM   #15
M L Struck's Avatar
what are you planning on doing with the car just have fun drag race what?
Old July 31st, 2009, 02:04 PM   #16
How do I check condition of stock rods? I want to make sure they are in good shape. And it will mainly be a DD but I want to be able to take it to the track a few times during the year and have fun with it
Old July 31st, 2009, 02:31 PM   #17
M L Struck's Avatar
Well if you plan on getting gt40 heads (used I assume) you will want to have a shop go through them so at that time have them hot tank the block and check out the rest of the lower end. This is all based on your skills and more importantly your funds
Old July 31st, 2009, 04:40 PM   #18
Alright sounds like a good way to go at it. How much does it cost to get it hot tanked? and how much would it cost to get it bored .030 on average?
Old July 31st, 2009, 06:52 PM   #19
baine21225's Avatar
+7648 marks all your bags/bolts
Old July 31st, 2009, 08:17 PM   #20
I learned that lesson when I replaced my heater core
Threads Similar to: Engine rebuild
Engine rebuild Cadillac 96-98 2 May 25th, 2009 03:44 PM
Engine rebuild mrnewall 99-04 5 June 21st, 2007 08:04 PM
Engine Rebuild Sh0gun! 99-04 3 March 8th, 2007 06:51 PM
Rebuild or new engine? 5point0 5.0 Mustangs 5 December 19th, 2006 03:06 PM
Engine Rebuild? slimboyfatty General Tech 7 December 11th, 2006 01:22 AM
