1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
bad night at the track..clutch problems please help!!
took the car to the track for the 1st time since having the tranny rebuilt, and the bolt on's...well to this point i have gotten on the car hard even launched it on a long road behind my house....but no burnouts...well tonight pull out the water pit..did a burn out went to hit the clutch and it very soft..and had to push it hard as i could to get it to dissengage...then let back up and it catches soon as i move an i stalled the car...then i pulled up staged reved to like 18 it grabbed hard and i was off went to hit 2nd and it wouldnt go...clutch is very hard to dissengage but i drove it home...once its going the car pulls fine no chatter or slipping from the clutch..any ideas??
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
1995 Mustang GT
other information...its a ram hd clutch. i'm still brain storming...is it possible to have bent the clutch fork?,?
clutch cable adjustable?
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
1995 Mustang GT
not just the self adjustment...ya know from pumping the clutch then lifting the pedal.
my cable got stretch out and was doint that, i have an adjustable one, so i just tightnd it up. check ur cable first
1982 GT t-top
no proof of purchase
It sounds like an adjustment problem ...Don't stock quadrants have problems with hd clutches?
i think my after market clutch cable sucks
Air gap not set right.....non adjustable clutches need to have a high pedal disengage....
PeteAndersonRacing.com |
1995 Mustang GT
well i mean before i did the burnout the clutch was fine...any ideas on how to fix this?
Adjustable cable and quadrant for starters. That should have been done before the heavy duty clutch.
1995 Mustang GT
yea stupid mistake on my part.....im not sure if the cable is stretched or not.i got under it...the cable doesn't have any slack...but if i grab the clip in the fork and wiggle it up and down..to the point if i push it hard enough up i could probably get it to slide out
12.8@103... stock motor
11.8@113...150 shot
you still need to adjust it...
It sounds like to me..
a) Stripped/broken quadrant b) Stretched cable Check and see if the fork is hitting your bell housing. It could have broke the pivot ball or slid off it causing some crazy geometry
weeee foooord!
1995 Mustang GT
sup guys just finished up fixing it...it was the cable i put an adjustable cable on it...and its working fine thanks again guys
aka Nature boy
blk 89/red 91 XJ Limited
I like turtles
good to hear man.
1995 Mustang GT
thanks man...still needs to be adjusted a little bit more..but it was gettin dark and the goddamn drop light kept burning my arm lol so i'll get it adjusted just right tomorrow..but its all good
#17 | |
aka Nature boy
I like turtles
1995 Mustang GT
curious anyone have any suggestions on what to put on the adjustable end of the cable to keep the nut from moving?
1995 Mustang GT
locktite or a locking nut? glad you got it fixed... what cable did you put into it? and did you replace the quadrant and firewall adjuster too? I hope so cuz those will be breaking next...
1992 Lx
11.39@119.24
theres supposed to be 2 nuts on it right next to each other so it doesnt back off
Threads Similar to: bad night at the track..clutch problems please help!!
| Good/Bad Track Night | beefmobile | 2005 - 2010 | 32 | October 5th, 2008 05:50 AM |
| Went to the Track Last Night? | 93HatchsBFF | 99-04 | 28 | June 11th, 2008 11:51 PM |
| Went to the track last night. | 1slo5.0 | The Clubhouse | 11 | September 8th, 2007 03:39 PM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 10:08 AM |
| Went To The Track Last Night | Drgnracin72 | The Clubhouse | 56 | October 4th, 2006 07:53 AM |
