How to tell if a lifter is bad..
Old July 27th, 2009, 01:00 PM   #1
1998 Cobra
13.24@105.66
I had some valvetrain noise in my motor.. tore it all apart and went with a set of freshly rebuild gt40p's with upgrades springs and ped roller rockers.
While it's all apart, I want to make sure to do this swap right so that dreaded ticking sound will go away.
How can I tell if one of my lifters is bad? It's a 120 $ for a set of 16 that I really dont feel like spending right now.
weeee foooord!
Old July 27th, 2009, 01:14 PM   #2
86er's Avatar
put a push rod on the cup and push, should have almost no slack/movement when you push, and only start to collapse when you put a good force on it.
Just a truck
Old July 27th, 2009, 02:48 PM   #3
1998 Cobra
13.24@105.66
alright thanks! I'll check them out.
weeee foooord!
Old July 27th, 2009, 03:54 PM   #4
1998 Cobra
13.24@105.66
took a push rod and pushed on each lifter. All of them took a good bit of force to make them budge but one. With the lightest pressure it would sink and didn't feel like the others.
weeee foooord!
Old July 27th, 2009, 06:21 PM   #5
86er's Avatar
you have one bad lifter
now you decide to just replace the one and get out cheap, or throw a new set of lifters in with the other new parts and know you are starting on a solid platform of new parts
Just a truck
Old July 27th, 2009, 06:49 PM   #6
Lifters are bad if they are not solid...lol
PeteAndersonRacing.com
Old July 28th, 2009, 12:53 AM   #7
1998 Cobra
13.24@105.66
I totally understand you there. Usually I would just replace everything with new, but right now finances are tight with tuition money coming up.
Worse comes to worse later on ill pop the intake back off and put a fresh set in.
weeee foooord!
Old July 28th, 2009, 12:54 AM   #8
1998 Cobra
13.24@105.66
I like mine tight haha
weeee foooord!
Old July 28th, 2009, 01:05 AM   #9
86er's Avatar
been there done that, built my car on a 3 yr plan just buying parts here and there.
Luckily if lifters are good its a part you can slide by with fixing just what needs to be fixed
Just a truck
Old July 28th, 2009, 04:46 AM   #10
MOTOIMPAIRED's Avatar
1990 LX Coupe
MOTOIMPAIRED is on a distinguished road
Last I looked the Summit brand rollers are $90 for a complete set.
Old July 28th, 2009, 01:30 PM   #11
1998 Cobra
13.24@105.66
That 90 bucks went to my calculus 3 book lol
weeee foooord!
Old July 28th, 2009, 02:25 PM   #12
86er's Avatar
my freshman year of college first semester $780 dollars in bucks, Facking sucks
Just a truck
Threads Similar to: How to tell if a lifter is bad..
Lifter Tick Chris951 5.0 Mustangs 10 March 11th, 2009 05:47 PM
solid roller lifter vs. hyd flat lifter ... pushrod length? ryans88gt 5.0 Mustangs 5 December 10th, 2008 12:19 AM
lifter for degreeing ajm 99-04 3 July 6th, 2008 08:10 PM
Lifter Question 95blackbeauty 5.0 Mustangs 1 June 12th, 2008 07:30 PM
How much lift at lifter? 5literJeff 5.0 Mustangs 2 March 15th, 2007 09:00 PM
