t5 to c4 swap?
Old July 28th, 2009, 04:31 AM   #1
RaceRelated's Avatar
RaceRelated is on a distinguished road
Thumbs down
t5 to c4 swap?
i am supposed to go pick up a dynamic c4 tommorrow. the car has a g-force t5 in it now. will the c4 drop in like cross member and drive shaft wise? thanks
Old July 28th, 2009, 04:46 AM   #2
anybody?!?!
Old July 28th, 2009, 09:46 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will have to modifiy the crossmember. Driveshaft is the same. What is wrong with your G-force?
Old July 28th, 2009, 10:10 AM   #4
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
sell me the G force
"Having a 9 second neon is like coming out of the closet, everyone is shocked at first, but in the end you're still gay."
5.4 Shelby Crew member #1
Old July 29th, 2009, 12:03 AM   #5
Originally Posted by M L Struck View Post
sell me the G force
its gone already i pulled it today in exchange for a 3 speed auto w/ brake
Old July 29th, 2009, 12:38 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Why? A G-Force is a good trans. What kind of auto did you trade it for? Did it come with a torque converter?
Old July 29th, 2009, 07:23 AM   #7
M L Struck's Avatar
I hope it is a killer auto
Old July 29th, 2009, 10:41 AM   #8
PeteAndersonRacing.com
Old July 29th, 2009, 10:50 AM   #9
1998 Cobra
13.24@105.66
5 speed > auto
weeee foooord!
Old July 29th, 2009, 02:17 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by superbean View Post
5 speed > auto
Sometimes, sometimes not. Depends.....
Old July 31st, 2009, 07:26 AM   #11
a dynamic c4, sfi bellhousing, cheetah, reverse body, brake, cooler, minus lines. im a 5 speed fan too, but nothing is like a launch off the brake
Old July 31st, 2009, 07:30 AM   #12
M L Struck's Avatar
Except if it had clutch
Old July 31st, 2009, 07:31 AM   #13
oh and yeah converter also, actually he said he just forked out 800 for the converter. i guess his car was falling on it face at the track or something, he thought it was the converter, bought a brand new one. It was a fuel pump ?!? and i stumbled along on craigslist with an ad looking for built c4 or aod and put the force up for sale or trade and he called me about an hour after posting it. he said it was either mine or a tko600 but that guy wanted a grand on top of his auto so we have been talking for about a week and im finally today going to pick it up. been workin my ass off and this weekend it is gonna pay off!
Old July 31st, 2009, 07:32 AM   #14
to an extent, but my car burns the tires leaving in 2nd on only 6psi
Old July 31st, 2009, 07:35 AM   #15
im changing the 4.10s too
Old July 31st, 2009, 09:48 AM   #16
e3sean's Avatar
1988 lx
9.68@142
i did the same swap and i have no regrets i love my tranny break!! ya the crossmember you will have to grind the spot welds on the mounts and slide the crossmember back a little then it will bolt right up.
<font size=4><b>MILITARY CREW
Old July 31st, 2009, 09:51 AM   #17
e3sean's Avatar
1988 lx
9.68@142
so your not confused.
when you pull the crossmember out there are 2 tubes that the long bolts go through.
well those metal tubes are just spot welded in like 4 spots on each side on the the crossmember if you grind them down flush you can make them slide back by hitting it with a hammer.
Old July 31st, 2009, 03:00 PM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will need a different converter. The one from the other guys set up will work but will be far from optimum unless your cars are absolutely identical, but even then the converter could be way off.
You should have stuck some money in chassis work before you swapped transmissions. If it blew the tires off with a manual, it will with an auto too.
Old July 31st, 2009, 05:21 PM   #19
JBIGBOOTSY's Avatar
1990 LX hatch
Transbrake FTW!
Old July 31st, 2009, 08:44 PM   #20
yeah im coming to that conclusion already. it stalls at 4k rpm, so i can kiss my gas milage good bye too, im gonna leave the brake disconnected till i get my torq boxes welded and everything, and im doing a coil over setup. ill keep it posted though. I got to go get some line from the hydraulic shop tommorrow.
BOOST CAN BE FRIENDLY
Threads Similar to: t5 to c4 swap?
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 12:57 AM
c4 swap help blue46gt00 Modular Mustangs 1 April 5th, 2009 09:11 PM
1995 351 to swap or not to swap.& how to? Jeffery9508 94-95 9 August 3rd, 2008 08:00 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
