NEW SELF ADJUSTER?
Finally got my trans back in with your help started the car and it will not go in to gear replaced the cable and still won't go WHAT DO I DO?
I'm assuming its an automatic???? Is the fluid full? When you put it back in was the converter all the way in the pump? Is the converter bolted to the flexplate?
all motor
92 coupe
9.94@136.40
smith check ur linkage. and check ur self adjusting mechanism may be damaged or bad.
no automatic it is a five speed
if i buy a new quadrant do i have to buy the adjuster to or can i use the stock cable with it ? i just bought the stock cable i guess can i still adjust the clutch from the pedal
1990 LX hatch
you'll probably have to buy the firewaall adj if you buy a solid billet quadrent.
Will it go into gear with the car not running?
yes it does go into gear with car not running
Does it grind when you try to force it? Does the clutch feel like it has good pedal, or too sloppy at the top of the tavel?? Seems like the clutch is still engaged, have you changed the cable since the last time you used the clutch?? retrace everything that you touched and eliminate problems one at a time. If all you did was change the clutch, and simply disconnected the cable from the fork, then maybe you didn't properly attach the end of the cable to the fork, on of my buddies had one time sandwich-nutted the cable to his fork, and the clutch would not disengage because the cable needs to pivot in the fork witha pivot nut....
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
Thanks for all the help ..... i had to use a screwdriver to adjust the cable selfadjuster wasn;t working but now we are in business now working on the heater core and backwards fuel gauge
Threads Similar to: NEW SELF ADJUSTER?
| Firewall adjuster | Drick | 5.0 Mustangs | 20 | September 26th, 2007 11:29 PM |
| timing adjuster | ujslost | 96-98 | 4 | April 28th, 2007 04:40 PM |
| Mass Air Adjuster | Zak | 5.0 Mustangs | 9 | April 22nd, 2007 11:06 PM |
| Steeda Timing Adjuster | WAR-PARTY | 99-04 | 23 | January 21st, 2007 09:17 AM |
