1990 LX Coupe
306 VS. 347 Piston Photos...............
Here I took photos of my Probe Factory stock 306 pistons and the Sportsman Race 347 piston. Yes the 347 has a shorter skirt and there is minimum clearance from the piston pin and oil ring but there is material there...
Posting these for those that have never seen a 347 piston but comment on the fact that they burn oil... ![]() ![]() ![]() ![]()
Priest of the Car Gods
Do you have weights for those two pistons by any chance?
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
1990 LX Coupe
I went to weigh them but the batteries in my one scale are dead and the other scale max's out at 300 Grams...
I will find out since it's not posted on the website.. I'll let you guess which one weighs less.... LOL |
#4 | |
aka Nature boy
blk 89/red 91 XJ Limited
I like turtles
1990 LX Coupe
i bet that 347 piston weighs a good bit less..
weeee foooord!
#7 | |
aka Nature boy
I like turtles
Subscribing...........lol
1990 LX Coupe
1980 Ford Mustang
WAY TO LONG
would you recommend boaring out a 302 to a 347,would you get the same performance
![]() 1980 mustang I6 200 0-60 in "get me an f'ing V8" |
#11 | |
Moving on, so you are a narcotics officer? I'm sure that is a job that never gets boring. I started to pursue a career in forensic science but I didn't get much further than the "starting to pursue" part. My current job is just too demanding right now to have the extra time for more schooling. Its definitely the field I want to be in though.
Same performance as what?
Wow, that is very thin material between the pin and the ring. I can see where people say that 347's burn oil of that clearance is on all 347 pistons. Maybe not on a new engine but put 5k miles on that piston and I'm sure with the temp cycles that the material gets weak and flexes. If I was a bettin man I would too say the 347 piston will burn oil first and even fail first.
![]() -Mark- 98' N/A Cobra (Stock longblock) 11.79 at 114.64 (1.62 60ft) |
90 GT
^good thing you aren't a betting man.
#15 | |
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#16 | |
You can bet all you want, 347s don't burn oil and these pistons are not going to fail. Probe makes a very good product. If there was any chance for reliability issues these pistons would never see the market.
#17 | |
Just a truck 5.4 3v: 264hp 317ft lbs rock stock piecing together the next project faster than your first sexual experience |
#18 | |
1990 LX Coupe
![]() That is the new design piston that I posted. Like you said, this piston has material above the pin, most dont. I was at my engine builders yesterday and he had some pistons that had nothing above the pin, and it was a high horsepower engine... No blow by or oil burning... I posted these pictures just to show those that have never seen a 347 piston and now I want to sit back and see the rumors fly!!!!
aka Nature boy
I like turtles
Them drugs keep alot of people employed, Seem you have quite the enjoyable job!!
#20 | |
Threads Similar to: 306 VS. 347 Piston Photos...............
| A few photos | zinc02GT | The Clubhouse | 5 | May 20th, 2008 09:55 PM |
| 347? about rod & piston combo | And then some | 5.0 Mustangs | 14 | October 5th, 2007 11:54 AM |
| 07 Photos + Some Mach Photos + My Girl's 06 | machfelon | Pictures | 5 | April 5th, 2007 12:01 AM |
| Photos | NYHigH | 5.0 Mustangs | 30 | January 9th, 2007 06:13 PM |
| 302,306,347,351-which motor would be best on boost (turbo) | 2ToneFox | 5.0 Mustangs | 5 | August 16th, 2006 10:36 PM |
