Cooling system question
Old July 30th, 2009, 11:00 PM   #1
04 Mach1, 89 Modded GT
snosourfur is on a distinguished road
Whats up guys,I recently started to disassemble my cooling system, the radiator is out, all hoses and thermostat housing are removed, tomorrow is the water pump and then i go to the store to buy all new parts etc......however upon disassembly I found alot of rust in the system and on the metal connecting components that the tubing from the thermostat housing connects to, im worried about there being more rust inside the engine block cooling resevoir and was wondering if anyone knows of a good way to cleans the system of rust before I reassemble it completely.....and yes I realize that leaving the system open to air doesnt help much at all but i didnt have a choice. please help..thx
Old July 30th, 2009, 11:58 PM   #2
nolife's Avatar
91GT, 88GT, 02GT
I've used various cooling system flush products in the past but they seemed to work as good as a few flushes of plain old water. I'd think that any chemical that gets rid of the surface rust would simply expose bare metal and cause another thin layer of rust to form again anyway. Maybe not. What ever you decide, make sure your final fill is close to a 50-50 mix.
Old July 31st, 2009, 07:00 AM   #3
ok, thanks for the input. id rather not spend the extra money on a chemical flush if it works the same as water.
Old July 31st, 2009, 09:45 AM   #4
e3sean's Avatar
1988 lx
9.68@142
when you pull the waterpump off put a hose in top where the thermastat housing was and let it run till the water runs clear then when you fill your system use distilled water and the addititive dont bother with antifreeze cause you live in florida you dont need it there is an additive in a little pink or green bottle that prevents rust.
<font size=4><b>MILITARY CREW
Old July 31st, 2009, 11:31 AM   #5
ok cool, i will do that, I am actually in GA right now, the temperature difference isnt THAT huge but come winter time, where i am at things start to freeze so should i be worried about it then or would you say it isnt cold enough here to need it? also in my trans am the distributor is notorious for going dead right after water pump replacement is that something id have to worry about in the 5.0?? thanks man
Old July 31st, 2009, 12:41 PM   #6
e3sean's Avatar
1988 lx
9.68@142
nope your distrubitor will be fine.
if your in a place where it snows then you may want to use antifreeze.
Old July 31st, 2009, 02:44 PM   #7
alright, thanks alot
Threads Similar to: Cooling system question
Cooling System Issue prosbloom225 V6 Mustangs 8 April 14th, 2009 07:51 PM
cooling system? competition orange 99-04 8 March 26th, 2009 08:28 AM
Bleeding the Cooling System MUSTANG V6 Mustangs 3 January 3rd, 2008 11:55 AM
07 cooling system upgarde dumps 2005 - 2010 2 May 29th, 2007 10:03 PM
96 GT Cooling System Upgrade ?'s Areteracing 96-98 5 January 15th, 2007 10:50 PM
