Need Help
Old July 31st, 2009, 05:42 AM   #1
1980 Ford Mustang
WAY TO LONG
80mustang200 is on a distinguished road
Need Help
Ok i got a 1980 i6 200 in my mustang and want to upgrade to the almighty 8 put i need to know if i am going to have to IMMEDIATELY have to swap trannies and rear ends to do this job. ( i have the money for an engine but not the entire kit)
Old July 31st, 2009, 07:00 PM   #2
baine21225's Avatar
is an i6 300 a 4 cylinder? if so, then i would switch all at the same time and save the future issues
Old July 31st, 2009, 09:30 PM   #3
1980 Ford Mustang
WAY TO LONG
i am not sure how to even start to answer that question without....calling my phsychiatrist. I will let you figure that one out.
How many cylinders does an I6 have
1980 mustang I6 200 0-60 in "get me an f'ing V8"
Old July 31st, 2009, 10:05 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will need to change the K-member and the transmission for sure. The rear end won't last long with any horsepower in front of it so you should upgrade that to an 8.8 right away as well.
Old July 31st, 2009, 10:06 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can't be serious.....an I6 is a 4cylinder?????
Old August 1st, 2009, 11:24 PM   #6
1980 Ford Mustang
WAY TO LONG
i sure hope you where joking on that but an I6 is an inline 6 CYLINDER
Old August 1st, 2009, 11:59 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You need to learn how to read....
Old August 2nd, 2009, 03:53 PM   #8
fateisajester's Avatar
1989 Ford Mustang
3 mins
fateisajester is on a distinguished road
Send a message via AIM to fateisajester
i have seen some pretty impressive numbers comming from those i6's. check out the the different parts you can get for it, i think you will be supprised to see what you can do with that i6. wouldnt it be cool to beat a "mighty 5.0" with a i6.... something to think about
Old August 2nd, 2009, 04:00 PM   #9
1989 Ford Mustang
3 mins
Old August 2nd, 2009, 04:49 PM   #10
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
that truck sounds pretty unique
spray and pray
Old August 2nd, 2009, 04:51 PM   #11
1980 Ford Mustang
WAY TO LONG
this may be a noob question but what is a Cam i hear it all the time and i am not sure what it is or does
Old August 2nd, 2009, 06:42 PM   #12
1989 Ford Mustang
3 mins
the cam controls valve lift and valve timing. lift=how much the valves open duration=how long the valve stays open
