1989 Mustang LX 5.0
Importance of heads on a turbo stock block car...
Im on the home strectch of aquiring all the parts for a T70 turbo setup, I also have a GT40 intake im going to put on at the same time, Also, I want to take the valve covers off and paint them.
My question is this - While I have the valve covers off would it be easy enough to replace the valve springs? Or do the entire heads have to come off? Also would just buying 'regular' valve springs be a fine replacement or should I not even bother if the car is running fine as is. Also - From what I can gather their is really no reason for me to try and put different heads on this engine since I can throw enough boost at it to crack it in half, Or am I missing something? Lastly - Anyone know if Pypes violator mufflers are chambered? Thanks in advance |
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
well i mean i dunno why you'd wanna put GT40 stuff on a turbo motor..
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
1989 Mustang LX 5.0
Why not? I mean I already have the thing, why not put it on? If nothing else It will give me a few horsepower off the boost, And probably more on.
1995 Mustang GT
i understand that...but what i'm saying is those heads aren't gonna flow good enough to support a turbo set up...at least i wouldn't think so.
1989 Mustang LX 5.0
Oh, It's a GT40 intake, not heads. The thing is you can run enough boost to totally destroy the stock block, So that's actually one of my questions. Is their ANY reason to run aftermarket head's when the stock block is the weak link? Im assuming their is some advantages (especially like getting into boost faster, and efficiency) - But actually worthwhile advantages?
1995 Mustang GT
yes...the flow better...and the heads are what controls letting air in and exhaust out...so you block will have a pro longed life if you can make it run more efficiently.
1990 LX hatch
You can take a stock motor to the 10's with enough psi. the downfall is youll make tons of torque, and have far lower hp numbers.
If you wanna do it, avoid the inevitable, turbo your stock motor, while you save all your money for a dart based block, top it off with your choice of proven heads intake...
#8 | |
1990 LX hatch
Actually the cam controls that.
1995 Mustang GT
yes i know i worded it wrong.
#10 | |
1989 Mustang LX 5.0
my friend made 400/450 at 8 psi on a freshly rebuilt motor. stock cam, gt40p heads, and a typhoon intake
just leave your stock heads and throw some boost at it.
weeee foooord!
1990 LX Coupe
Bigger injectors and a MAF to match and boost that thing!! Your not going to split the block so dont worry about it..
Threads Similar to: Importance of heads on a turbo stock block car...
| 4v heads on 2v block? | energiesource | 99-04 | 5 | November 25th, 2008 06:41 AM |
| short block's block vrs block in car stock? | adrenaline=lifeline | 99-04 | 7 | August 19th, 2008 08:22 AM |
| 3V Heads Onto A 2V Block? | ModMustang97GT | Modular Mustangs | 24 | July 23rd, 2008 08:41 PM |
| block and heads | compgun | 4V / SVT | 6 | July 23rd, 2008 01:51 PM |
| Stock Cobra Block and GT Block the same?? | bbrewer03 | 96-98 | 2 | August 26th, 2006 01:31 PM |
