cooling issues
Old July 31st, 2009, 10:47 PM   #1
1998 Cobra
13.24@105.66
cooling issues
I just got done doing a p head swap and i'm having cooling issues..
I started the car up with the cap off and topped it off and kept adding coolant until it started comming out the top. Put the cap on and it would stay at about 160 deg for about five minutes then it would climb quickly to 270/overheating.
Where do I go from here?
weeee foooord!
Old July 31st, 2009, 11:45 PM   #2
1998 Cobra
13.24@105.66
help! LOL
weeee foooord!
Old August 2nd, 2009, 07:40 PM   #3
fateisajester's Avatar
1989 Ford Mustang
3 mins
fateisajester is on a distinguished road
Send a message via AIM to fateisajester
it probably an air pocket. you're going to have to burp it. top off your radiator, run the car with the cap off, turn your heater on if you have one. when the car starts to warm up keep the your garden hose in the radiator and let it keep running until it stops "burping". if it starts to get too hot, stop, put the cap back on and wait for it to cool back down. start the process all over again. once you're done use the drain plug on the radiator to let some water out and add coolant. you want full strength for this part because its going to get diluted in your system. then run the engine for a while for everything to mix well, test the coolant in your system. if its too rich, drain and add more water. too diluted, drain and add more coolant
Old August 2nd, 2009, 08:01 PM   #4
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Most likely air bubble in the system. Definatley try burping the system some more.
Old August 2nd, 2009, 11:21 PM   #5
1998 Cobra
13.24@105.66
To follow up:
That's exactly what it was guys. I ran it some more with the cap off, parked it on a slight hill to help ease the air out. Put a new t stat and cap on, voila, it stays at 170 deg all day!
weeee foooord!
Old August 3rd, 2009, 12:53 AM   #6
1989 Ford Mustang
3 mins
Originally Posted by superbean View Post
To follow up:
glad to help
Old August 3rd, 2009, 03:43 AM   #7
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
how do you like the heads man?
Old August 3rd, 2009, 11:56 AM   #8
1992 Lx
11.39@119.24
Originally Posted by 1989Gt. View Post
how do you like head man?
coughyoulikeguyscough
Old August 3rd, 2009, 01:26 PM   #9
1998 Cobra
13.24@105.66
sucky sucky fife dollah.
The engine feels solid. Still can't drive it hard as I have a massive collector leak and im sure the oxygen sensor is like WTFFFFFF
weeee foooord!
Old August 3rd, 2009, 01:33 PM   #10
e3sean's Avatar
1988 lx
9.68@142
i bet you had the thermastat in backwards.
<font size=4><b>MILITARY CREW
Old August 3rd, 2009, 01:35 PM   #11
1998 Cobra
13.24@105.66
That's the first thing I checked, it was in correctly.
I'm thinking the overheating was caused by a bad cap, because i stole the one off my drag car and put it on the black one, and visa versa.. drove the drag car around and got up to 220 deg pretty damn fast.. faster than it used to.
weeee foooord!
Threads Similar to: cooling issues
Cooling Issues Quick Question... burnout5.0 94-95 4 March 22nd, 2009 02:07 PM
cooling issues 232stang General Tech 0 March 11th, 2009 04:20 PM
Cooling Down scramblr 2005 - 2010 14 September 9th, 2008 12:22 AM
Cooling usafimj 2005 - 2010 4 June 25th, 2008 11:19 PM
Cooling Issues rendus688 V6 Mustangs 39 January 31st, 2008 11:09 AM
