LinkBack (3) | Thread Tools |
#1
Need help on my first mustang
Hello, i just got myself an 89 gt. Its my first muscle car. I was always into the import scene and autocross. I always owned miatas, 240sx and the classic corolla. Someone came up to me and offered a trade my ae86 for his gt. I took my dad who grew up with mustang and we made the deal.
It ran great, no problems on taking it home. That same weekend i took it for a smog and it passed with no issues. As soon payday came up today, i did the oil change replaced the air filter. I had spark plugs ready, but was getting late and needed to meet up with my buddies. Today it ran great nice and smooth, i went for gas added 7 gallons, drove to pole position when we finished at the track the car was fine, same thing after having late dinner with my friends. Now i came home, shut the car off. Move my families car out of the driveway to store mine in the garage. I turn the key and the engine turn, start for a bit, stumbles and dies. I try pumping the gas while stubling and i can hear the suction from the filter and pop or gasp of air sound coming from filter. I turn the key i can hear the fuel pump running. My dad came out to help me out, what he was doing was turning the key on and off a few times to get fuel. When it engages i can hear the pump running till the car dies and pump stops. I cant figure out whats wrong, with the car if it was running so smooth. I can hear the pump running so i know its the not the pump any ideas |
1989 GT
KB 2.1L Flowzilla
Welcome to the forums!
Start by scanning for codes. Ford Fuel Injection » How To Run a Self-Test Hearing the pump isn't enough to tell for sure that it's working properly, or fuel filter might be clogged, check fuel pressure. |
MM.s Used Car Whore
2011 F150 XLT 4x4 5.0
14.89
most likly fuel filter..
alright thanks for the info, i dont get what happen but like i couldn't get the car into the garage i left it outside. I wake up getting ready to work on it, i turn the key and the car started right up and not acting funny just idling perfect. The one thing i do hear is a humming or long beep noise coming from the back
the noise you hear is the fuel pump operating normally. Everyone's fuel pump whines with these cars. i would change your fuel filter and make sure you do a full tune up and check up on the car alot if you are road racing with it, it is important for your vehicle to be in tip top shape its hard on a car.
#6 | |
88 LX 5.0 Convertable
Robbie_________________ 88 LX Convertible 5.0 84 GT - Project 66 F100 |
1993 5.ohhhh
12.97 @140mph
you pump should only wine or buzz real quick while in the auxilery position with the key before turning the car on. If it continues to buzz it can be a hint that the pump wont last long.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
Welcome to MM. Don't get on Darrel's bad side and enjoy
weeee foooord!
aka Nature boy
blk 89/red 91 XJ Limited
I like turtles
+1000
And welcome to MM! and the Mustang world!~ your one of the cool kids now. <--
Who is this Darrell guy that you speak of?
I bet the best way to avoid his wrath is to no spew bullshit from your mouth. I hear he hates internet bullshit.
#12 | |
...... * awaits the 347 issue topic once again.........
weeee foooord!
Atomized
93hatch and gotn20 police the e thugs around here to so watch out for those two assholes....
spray and pray |
i think i may know exactly what your problem is... you said it ran fine for a while and then you shut it off then couldnt get it started again? then in the morning it ran fine again. i had the same problem. took me months to figure out what it was. turns out it was the pip sensor in the dizzy. when it gets hot its starts acting screwy... once it cools off, everything is fine again. its a bitch to replace that sensor, just get a cheap rebuilt dizzy from the parts house and you shouldnt see this problem again. make sure when you replace the dizzy, you mark the rotor location and try to match the same angle of the connector in front of the dizzy so you will be pretty much "close" to the timing that you were at before. but i would still check it with a light to be sure
alright, i checked codes first set is 31, then the second set was 11. thanks for the welcome everyone feels cool just cruising on mustang. fateisajester i think your right too, my dad grab some ice into a plastic bag wrapped it around shop towel. When i was having the same problem again later in the afternoon. At first i thought it was the alarm so it was PITA removing it and connecting everything back again. My dad brought out the ice bag placed it against the sensor on the dizzy let it sit, i turn the key and started right up.
Replacing the module easy? its cuz i just paid of my class for next semester and im broke lol Last edited by medic4.life; August 2nd, 2009 at 05:40 PM. |
its not the box on the outside of the dizzy, it a sensor INSIDE it... you have to pull the shaft out to replace it
if you're working on a budget, although it may not look very "cool", get some some of that conduit they use for clothes dryers on the exhaust vent at a hardware store. route it through your bumper somewhere and have the other end point at your dizzy... kinda like a ram air setup, only it will be blowing cool air on your dizzy. it may just keep it cool enough to function correctly
replacing the dizzy, do i need to set motor TDC. Or can i just remove the bolt holding it down and drop the new one in
Did you mark where the rotor points on the dizzy? If not then you need to bump it to tdc and stab it in.
weeee foooord!
no i havent picked it up yet, i wanted to just prepare myself and know what im getting into
fateisajester what brand did you purchase on your dizzy, payday this thurs for me Last edited by medic4.life; August 19th, 2009 at 02:15 AM. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/132244-need-help-my-first-mustang.html
| 79-04 Mustang parts, ‘97 Eclipse parts. (Dade) - Mitsubishi Eclipse Parts | This thread | Pingback | September 29th, 2009 10:28 PM | |
| Need parts for Mustang and Eclipse??? - Mitsubishi Eclipse Parts | This thread | Pingback | September 26th, 2009 02:26 AM | |
| Mustang and Eclipse starters and alternators! - Mitsubishi Eclipse Parts | This thread | Pingback | August 27th, 2009 12:51 PM | |
Threads Similar to: Need help on my first mustang
| Live Broadcast at 5:30 PM Central: Mustang Stories Contest Winner Gets His Mustang | unlicensed to drive | The Clubhouse | 30 | July 7th, 2009 09:03 PM |
| MOFO Production-Turbo 5.4 Stang-600HP Mustang GT-408w mustang-Ported Blower Cobra!! | mofobucs | Multimedia | 24 | August 20th, 2008 01:19 PM |
| Memphis Street Racing 4-13-08 LT1 Z28 Turbo Mustang LS2 GTO WRX STI Audi TT Mustang | Mellon | Videos | 4 | April 17th, 2008 08:54 PM |
| Pirelli P6 Four Seasons fit on 17x8 mustang rims? 97 mustang | DiegoAlcala | V6 Mustangs | 7 | April 20th, 2007 09:04 PM |
| So Md Mustang Club 3rd Annual Mustang & Ford Show | Hwyman | Mid-Atlantic | 0 | August 8th, 2006 03:39 PM |
