alternator help
the battery kept going dead and i charged the battery more than twice wondering if it was the probablem. i pulled off the connections and the car died so i figured it was the alternator. i bought a brand new one and a plug and it seemed to work for 30 miles but came night as soon as the lights went on the volts said below 8 and wouldnt start back up as soon as i killed it. its not getting any charge back please help
o and its a red top optima
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump and more to come
and i tried a diff battery interstate and same thing
Pulling the cables off is not the way to tell if the alternator is bad. I know alot of people think that is an alternator test but it is not.....as you have found out.
So you have a new battery and a new alternator which means there is only one thing left in the charging system, wires. Did you replace your alternator plug with the one that came with the alternator? Did you solder the connections? That harness commonly causes charging problems and sometimes fires. I've fixed alot of charging issues on Ford cars with that style alternator with just a new connector. Besides the connector check all of your grounds. You should have a ground from the battery to the engine and from the engine to the firewall behind the engine.
1990 LX hatch
+1^
Most of the time it's a loose or dirty connection..
Do you have access to a volt meter? If not I would highly suggest investing in one. Let us know what you try/find.
weeee foooord!
my buddy had a volt metter tester last night and it was 11. something and dropping slowly. but when i first put on the new alternator it was very slowly charging for 11.89
the oem harness has inline fuses for the charge wires. Check for continuity to ensure juice is actually getting back to the battery
weeee foooord!
Threads Similar to: alternator help
| R.I.P. Alternator | AggieStang | 99-04 | 59 | March 10th, 2009 12:20 AM |
| 3G Alternator | mustangsoldier | 5.0 Mustangs | 3 | March 9th, 2009 02:19 PM |
| Alternator? | thekeysbucket | 5.0 Mustangs | 18 | March 4th, 2009 12:32 PM |
| alternator | WilltheThrill | 4V / SVT | 5 | February 2nd, 2008 09:28 PM |
| alternator | Murderjetz | V6 Mustangs | 6 | July 26th, 2007 08:53 AM |
