#1 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
Rpms fall if I give a quick blip of the gas
Lately when I start up my car the car seems to want to hold high rpm for longer than normal(like on a cold start) and when I start to go from a stop it seems like it hesitates or sputter of a second and then it finally catches up.
Today at the gas station I was giving it a couple quick blips on the gas and instead of revving up the rpms dropped. It also seems like its not as fast as it used to be. I am changing the plugs tomorrow because I haven't done it in a while but if that doesn't help it what do you think it could be? Timing is at 14 and fuel pressure is at 30 if I recall right.
u running carburetor?
1987 ford mustang gt
well see when shes done
fuel pressure gives it away that hes injected..
First off i would get a fuel pressure guage and turn the pressure up to atleast 39, then i would keep it on there to see if it was holding constant pressure or fluxuating when you give it gas.
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
1990 Mustang gt
I'd also check for vacuum leaks. My car was running all kinds of shitty when I first got it, wouldn't idle consistently, almost sounded like it had a cam, would hesitate when giving throttle.
It was a dry rotted hose attached to the underside of the upper intake.
2002 gt 5-speed slow 1990 gt 5-speed junk |
#5 | |
Holy Dick Castle!
Here is a crappy video. You cant even really see it but around 8 seconds you will see it drop when I barely touche the gas.
1988 Mustang 5.0 LX
12.48@118.27
I've had the same problem with my car it would surge when the car warms up and throw codes my fuel pressure was running at 10 psi when it should be at 40 then I had to change the fuel pump
1988 Mustang 5.0 LX
12.48@118.27
Is the engine bogging
#8 | |
Holy Dick Castle!
I hope I don't have to change the pump its a 255 not even a year old.
1988 Mustang 5.0 LX
12.48@118.27
you usually have a warranty for a year what maker is it
#10 | |
Holy Dick Castle!
I fixed it. I had read somewhere that there was more hp at 29 psi, I adjusted it to that not taking the vacuum line into consideration. And then I tried adjusting it without a gauge after it started acting up, finally got a gauge and it was at 50 psi
its back to 39 now and running better.
Threads Similar to: Rpms fall if I give a quick blip of the gas
| just a quick gas ? | stage2ROUSH | 2005 - 2010 | 20 | April 4th, 2009 10:38 PM |
| Sappers! FALL IN!! | BlackSunshine | The Clubhouse | 13 | October 29th, 2008 06:08 PM |
| Cant fall asleep :( | Drick | The Clubhouse | 20 | August 21st, 2008 05:32 AM |
| Well I cant fall alseep :( | Drick | The Clubhouse | 22 | May 5th, 2008 05:05 AM |
| best fall ever | flattusmaximus78 | Videos | 11 | August 13th, 2007 06:50 PM |
