255lph & 8.8 axle install advice
Old August 7th, 2009, 12:38 PM   #1
1989 Mustang LX 5.0
sniperd is on a distinguished road
I need to install a 255lph fuel pump, and an 8.8 axle into my car, The car has a 7.5 in it right now but its an 89 (Guy before me swapped this POS into it).
So I plan on dropping the tank first, then doing the axle to free up space.
Does anyone have any advice for me on either of these 2 installs, preferably the tricks/tips that make it go easier (especially how to position the axle for installation, and if i will need new bushings, etc).
Old August 7th, 2009, 12:43 PM   #2
1992 Lx
11.39@119.24
both extremely easy but the diff will be a ton easier with a hot muscular shirtles friend helping
Old August 7th, 2009, 12:58 PM   #3
1989 Mustang LX 5.0
Care to join me ?
Old August 7th, 2009, 01:00 PM   #4
1992 Lx
11.39@119.24
dude thats gay
Old August 7th, 2009, 01:01 PM   #5
1989 Mustang LX 5.0
dude thats gay
hahahaha
You started it.
Old August 7th, 2009, 01:10 PM   #6
1992 Lx
11.39@119.24
seriously though theyre both easy jobs, but the diff one will be MUCH easier with a friend, just dont forget to unhook the brake lines and emergency brake cable
Old August 7th, 2009, 01:13 PM   #7
1989 Mustang LX 5.0
did you just use 2 floor jacks to keep the diff up, or did you place it on jackstands first?
Old August 7th, 2009, 01:14 PM   #8
1992 Lx
11.39@119.24
car up on jackstands with the jack under the center of the diff, that way you can lower it to get to the upper control arms
Old August 7th, 2009, 01:41 PM   #9
EscortSportage's Avatar
1989 Mustang GT 5.0
i could be that muscular guy with no shirt...(for a cheap one time fee)
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Threads Similar to: 255lph & 8.8 axle install advice
axle bearing install GreyWarrior07 99-04 2 June 17th, 2009 06:23 PM
800+ for hurst&aluminum shaft & install? walkerman180 2005 - 2010 8 July 9th, 2008 06:05 PM
sub & amp install mach 460 2001 gt gwilkrrs Audio/Video 2 June 3rd, 2008 01:18 PM
Noise From Rear Axle After 4.10 Install Vabeachmustang 2005 - 2010 18 June 13th, 2007 11:31 AM
