short sweep and full sweep gauges.
Im looking at getting gauges for my 5.0 and Im not understanding what the difference between full sweep and short sweep gauges are. And what about When it somes to A/F gauges? Whats the difference between wideband and standard A/F gauges? I know the wideband gauges cost a crap load more than a stardard A/F gauge. Do I need a wideband or will i be ok with a standard A/F gauge. A/F is an important gauge but I dont want to buy an expensive wideband A/F if it isnt necessary.
1989 Mustang GT 5.0
get a wideband, the basic AF is garbage, its not accurate ,its just gonna jump from rich to lean and when your on WOT itll be right in the middle, i think short sweep is just a short range of numbers, full sweep is from 0 to what ever, its a full range of numbers depending on guage,
10 point Cage Bunch of newer mustang parts Maximum Motorsports catalog Sparco stuff "a huge bad azz motor is nice untill you have to turn or stop" |
Moderator
^correct. A wideband (although expensive) is a wise investment especially if you plan on modding. It will tell you the health of your car whether she is rich, stoich, or lean. as stated it is by far more accurate then the cheaper one. there is nothing more important then knowing how your engine is doing when you are WOT.
![]() ![]() BUILD 2 IN PROGRESS |
1989 Mustang LX 5.0
A short sweep gauge basically is less detail, as the gauge numbers are closer together, Say 70 degree's of 'change' in the needle. Well a full sweep might take up 3/4 or more of the gauge.
Short sweep - Auto Meter 5927 - Auto Meter ES Series Analog Gauges – SummitRacing.com full sweep - Auto Meter 6463 - Auto Meter Nexus Full Sweep Electric Analog Gauges – SummitRacing.com |
1989 Mustang LX 5.0
Look at the AEM UEGO wideband, its not too expensive
Threads Similar to: short sweep and full sweep gauges.
| So is the mechanic full of it??? | Traidmarx | 5.0 Mustangs | 42 | February 1st, 2009 11:57 PM |
| Full cage | forensicsteve | 2005 - 2010 | 19 | May 4th, 2008 06:07 PM |
| Is He Full Of It? | WilltheThrill | All Other Vehicles | 16 | December 17th, 2007 04:06 PM |
| i'm dangerously full | B0B | The Clubhouse | 22 | August 8th, 2007 07:44 PM |
| MMR Short Block vs DSS Short Block | superbeef1000 | 99-04 | 6 | September 20th, 2006 05:49 AM |
