Discussing O-Ring in the 5.0 Mustangs Forum. i am looking at getting trick flow heads with o-ring grooves (so i get ...
Old February 5th, 2007, 03:33 PM   #1
O-Ring
i am looking at getting trick flow heads with o-ring grooves (so i get the 1/2 in head bolt size for my 351w) and was just wondering what you guys have paid for o-ringing the block.
thanks
1995 GT::Sold!
Looking for another stang...
Old February 5th, 2007, 03:58 PM   #2
vfast's Avatar
why would you need to o-ring the block for..are you going to be using a 300+ shot or 20 psi on a turbo ..if not you don't need it
EVERYONE IS ENTITLED TO MY OPINION
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter
Old February 5th, 2007, 04:59 PM   #3
JOEYD0730's Avatar
i wouldnt o-ring em, i the new gaskets out there are great and i have been told it not needed unless you are making more that 18psi of boost. in my current setup i do have the block o-ringed. i am in the process of having a 331 dart block built with afr's. without o-rings.
91 Gt Convertible
RNH Perfomance 331 dart stroker w s-trim
http://i31.photobucket.com/albums/c3...0/HPIM0075.jpg dart stroker with s-trim, 91 vert
Old February 5th, 2007, 06:15 PM   #4
the reason i wanted to is because the only trick flow heads that use 1/2in head bolts, in the config i want, use o-ring gaskets. would it be easier to just have the (7/16in) heads machined to use 1/2 in head bolts?
1995 GT::Sold!
Old February 5th, 2007, 06:41 PM   #5
or can i use o-ringed heads w/o o-ringing the block???
1995 GT::Sold!
Old February 6th, 2007, 01:30 PM   #6
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Don't get the o-ring heads. They are not needed. Just use a good MLS head gasket. I know guys running big superchargers and turbos that don't use o-ring junk. That is a thing of the past. What configuration do you want? Because as far as I know all TFS heads come drilled 1/2" and to use them on a 302 block you use the 7/16" bushings that they supply.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old February 6th, 2007, 03:29 PM   #7
im just lookin to buy a pair of the twisted wedge heads (non-cnc) with the dual valve springs for up to .600" lift with 1/2" head bolts....if you look on summit at TFS-51400005 and TFS-51400004, the TFS-51400004 dont have the bushings under the "suggested parts" this also agrees w/ the trick flow site
1995 GT::Sold!
Old February 6th, 2007, 03:51 PM   #8
1995 GT::Sold!
Old February 6th, 2007, 04:00 PM   #9
i talked to a guy at trick flow and there is a little restriction thing i have to drill out...so prob solved
1995 GT::Sold!
Old February 6th, 2007, 05:23 PM   #10
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
It appears they don't use the bushings anymore.
Right off the TFS website:
NOTE:
Maximum camshaft lift with factory flat top pistons: Twisted Wedge: .540" lift; Track Heat: .600" lift
Check piston to valve clearance before installation
Stock stamped Ford rocker arms are not recommended
Dome-style pistons interfere with Trick Flow’s unique combustion chamber design. Conventional flat top or dished pistons will work
TFS-51400002, TFS-5140004, and TFS-51400010 heads use 7/16" head bolts. 1/2" head bolts can be used by drilling out restrictions
TFS-51400003, TFS-51400005, and TFS-51400011 heads use 1/2" head bolts
Old February 6th, 2007, 10:13 PM   #11
yeah, thats why i was askin, haha
well, thank you for the help
1995 GT::Sold!
Threads Similar to: O-Ring
Ring and pinion gear question 06silvergt 2005+ 2 September 13th, 2007 06:29 PM
So I hate when people ring the doorbell. energiesource 99-04 0 July 31st, 2007 01:30 PM
Let Freedom Ring Stangzilla Videos 17 July 23rd, 2007 12:09 PM
For anyone who has done a ring gear install MySallyMI V6 Mustangs 8 May 27th, 2007 12:59 PM
"ring ring" HMUSN The Clubhouse 12 March 21st, 2007 09:27 PM
