Foxbody C4?
Old August 11th, 2009, 07:07 AM   #1
stangage's Avatar
stangage is on a distinguished road
Foxbody C4?
I have a 89lx it has the stock AOD in it now and its goin out, I am building a new motor for it and want to replace the tranny as well, i have an extra AOD in good shape but I would like to put a C4 in, what yrs will bolt up and what things will i have to change for this to work? thanks for your help
"That old Ford sure fast on the draw out run the Chevys and out run the law"
Old August 11th, 2009, 09:10 AM   #2
flamestang's Avatar
flamestang is on a distinguished road
basically you want a 1970+ c4 case fill there are lots of research you can google a 164 bell will let you keep your flex plate.but the 157 bell is smaller for header clearance.here is one link
C4 Transmission 101 - Click Click Racing Forums
Old August 11th, 2009, 09:37 AM   #3
rodeheavers's Avatar
1981 4 EYED FREAK
9.48@147
rodeheavers is on a distinguished road
yep, try to get a big bell, 26spline imput shaft with the stick in the case..
www.rodeheavershotrod.com
9.48@147 on pump gas through the
mufflers, still has pw,tilt,t-tops,all
lights, wipers!!!, check out the vid
http://www.youtube.com/watch?v=SloE3Zdetac
Old August 11th, 2009, 01:15 PM   #4
stangage's Avatar
great thanks, so anything after 70 will be good? what will i all have to change just the flex?
Old August 13th, 2009, 08:47 AM   #5
Silverfoxbody's Avatar
Silverfoxbody is on a distinguished road
Send a message via MSN to Silverfoxbody Send a message via Yahoo to Silverfoxbody
The AOD 164 t flex will work with the large converter - but yes you need the 157t flex for the small bell. 70+ would be best to get the reliability.
Threads Similar to: Foxbody C4?
Which Foxbody is #1 Speedstang302 5.0 Mustangs 76 March 24th, 2012 09:35 PM
my new foxbody forcefedfox 5.0 Mustangs 13 June 12th, 2009 12:48 PM
A/c on 93 foxbody sctravis77 5.0 Mustangs 2 March 6th, 2009 07:39 PM
90 foxbody 1990gtfreak 5.0 Mustangs 7 June 3rd, 2007 12:02 AM
