Discussing Misc. problems in the 5.0 Mustangs Forum. ok first off when the car is warmed up and you go to start it ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Moderator
Misc. problemsanother thing i have a problem with is when it starts right up or if it takes a minute or so is that the idle stays at around 1500 for about a minute and then slowly goes down to about 800-900 RPM. then if i rev it to 2,000 rpm it will shoot down to about 1400-1500 RPM and stay there for about 5 seconds and then go down to about 1000 RPM and then there for a couple seconds and then down to 8-900 RPM. and when im driving or its idleling a gray or a white smoke is coming out the tail pipes and usally the ground where the smoke hits, there is a wet spot. when smelling the smoke it doesnt smell like oil or anything. just smells like normal exhaust fumes. anyone have any ideas. 1992 Mustang LX 5.0
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
Check all your vaccum lines, sounds like you have one either missplaced or a cracked one...........if its not that then, it could be timing or throttle positioning
I would check the TFI module in the distributor.
2003 Mustang Mach1 1995 Thunderbird LX 4.6; 4R70W w/Jmod, 8.8 3.27 Tracloc 1995 Mustang 4.2; MPX Supercharger/25%OD, 4R70W w/Jmod, 8.8 3.73 Tracloc (343rwhp/420rwtq) |
#4 | |
Mine did the same stuff when i put my motor back in, it was a vaccum line that i had crossed and or forgot to hook up lol |
Moderator
ok ill check the vacuum lines tomorrow. anyone have a diagram to which lines go into to where in the vacuum tree. and i did notice something in the engine bay that looks like it should have a vacuum line going to it but there isnt one and i have no idea what it is but when looking at the engine from the front of the car. the left side, kind of underneath things near the head/headers. from a map i have a the 5.0 it looks it can be a canister purge solenoid.
does any one have a pic of that i can see to see if that what im looking at cause i really cant see it on the 5.0 map.
Moderator
ok the thing im talking about is connected to the smog pump.
here is a rough copy of what should go where......
diggin for a more specific copy to your year now |
all those things seem to point to your timing not being right or its not advancing
Moderator
This is the part i was talking about that looks like it needs a line on it but doesnt have one. it connects to the smog pump.
allright i see if your smog pump is still all hooked up to the exhaust and everything, then that could be your problem. That thing in your pic is the bypass valve that comes off the smog pump. there is supose to be a vacuum line coming off of it. I had the same problem but i just took everything off the smog and plugged the tree. easier way to do it, that diagram i showed you before has the lines shown you need.
Moderator
i have emissions where i live so i cant mess with that stuff but look at the first pic i have posted in this post. on the top right has nothing going in to it and on the bottom right theres no vacuum line coming out of it. is that where the air bypass valve hose is supost to go in to? 2nd pic has a vacuum hose going into the tree but looks kind of crimped/bent.
Moderator
ok i think i found the cause of my hard warm start problems. the ECT sensor is bad so im going to go ahead and replace that.
where can i get this sensor at. is it something i can get at a car parts store?
1999 Ford Mustang V6
local parts store, i think it will probably cost you between $15-$25 you might want to call it a coolant tempeture sensor when you go there, because some parts fetchers are not smart enough to know what a ECT is.
...even fire and single cammin |
Moderator
will do. hope they dont get it confused with the coolant temperature sending unit tho. whole different part.
Moderator
ok well i think my motors gonna be done soon. i hear ticking on the driver side in the engine bay and also a crap load of blue smoke coming out the pipes. and a little knock when i hear closley on the passenger side. i really dont want to put any money into this car anymore so i think im gonna sell it as is or part it out and maybe get a 86 GT ive been wanting to get since i sold my old 86 a few years ago or so.
Threads Similar to: Misc. problems
| Misc Mustang Parts Must Go! | caintcatchmyGT | For Sale | 3 | December 12th, 2007 02:12 AM |
| Repost : misc 4.6 parts | caintcatchmyGT | For Sale | 11 | September 28th, 2007 08:30 AM |
| Misc Parts | turbong | For Sale | 9 | September 11th, 2007 09:15 PM |
| FOR SALE 05+ mustang misc. | 2007calispecial | For Sale | 0 | July 23rd, 2007 01:09 PM |
| fs:4V parts and misc.... | 1fstmach | For Sale | 35 | July 20th, 2007 07:01 AM |
