#21 |
Moderator
and you dont need vacuum to have the oil get into the catch can. The crankcase pressure is basically gonna push that stuff out into the can
![]() ![]() BUILD 2 IN PROGRESS |
#22 |
1993 5.ohhhh
12.97 @140mph
But the one line from the catch can to the filler neck vac hole is enough?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#23 |
Moderator
yeah but if your gonna do it you might as well do it right and do the PCV as well.
#24 |
1993 5.ohhhh
12.97 @140mph
no issues with that. Would it go into the lower intake or the upper intake and block off either or. Or could I run a "t".
And I'm guessing if I run the catch can to the pcv I could do a breather on the valve cover?
#25 |
Moderator
you can "T" it off. basically what you wil have is a length of hose connected to the PCV on the back of the lower manifold, a length of house connected to your filler neck, these 2 hoses will connect to the "T" connection, then a line will come from the "T" and lead into the catch can
#26 |
1993 5.ohhhh
12.97 @140mph
Sounds good. I appreciate it. since the pcv isn't going to the upper intake anymore what is best used to block it off?
#27 |
Moderator
to block off the connection on the bottom of the upper intake manifold go to your local auto parts store and purchase a cap set. The PCV valve is going to be left in place and the only thing different is that it is going to have tubing leading directly into the catch can.
#28 |
Proud American
Might be a stupid question, but why can you not just use breathers? Thats what I have on my race car... I have never played with boost though.
#29 |
Moderator
you can use breathers if you want. if you read my other posts there are a couple disadvantages to them, mostly that they tend to let smoke enter into the cabin since they are vented directly to the atmosphere but that all depends on the condition of your engine. another thing is that at times the breathers may get oil soaked dripping oil onto your valve covers. other then that there is nothing wrong with using them.
#30 |
1993 5.ohhhh
12.97 @140mph
I Did some more thinking. The pcv is technically connected to the line comming off the upper intake. Do I cut the hose... stuff it in the lower intake, and plumb a hose from the pcv to the catch can? Then I block off the upper intake.
Cause the key is to still run the pcv even off the catch can correct?
#31 |
Moderator
just block of the upper intake connection completely then have a line going from the PCV to the catch can
#32 |
1993 5.ohhhh
12.97 @140mph
I know, but should I just use the pcv hose that came off the upper. Cut it from the upper, put it in the lower, and connect it to the "t".
#33 |
1990 LX hatch
Use the old exhaust breather kit?
Threads Similar to: home made catch can
| home made tint | wishIhada5.0 | 99-04 | 11 | February 1st, 2009 01:22 AM |
| home made catch can | wraitherx | 4V / SVT | 13 | January 14th, 2009 07:35 AM |
| Home made powerpipe | sxynerd | 99-04 | 22 | May 11th, 2008 09:47 PM |
| Home made Subs | Blackblurr_00GT | 99-04 | 1 | July 8th, 2007 02:30 AM |
| home made turbo? | Orangester | V6 Mustangs | 20 | April 11th, 2007 03:00 PM |
