Problems With Oil Pressure Gauge... Need Help!
Old February 6th, 2007, 08:05 PM   #1
chase's Avatar
1987 Mustang LX
chase is on a distinguished road
Send a message via AIM to chase
my oil pressure gauge is acting weird. there is no consistency and it goes from a normal reading to nothing and then back to normal...how can i find out if im losing oil pressure of if its just a bad gauge...i need help im about to make a long road trip and i want to make sure everything is working properly...
Old February 6th, 2007, 08:06 PM   #2
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
Build #1249
MM New Edge Crew Member# 6
Old February 6th, 2007, 08:30 PM   #3
Stangzilla's Avatar
Stangzilla is on a distinguished road
Try changing you oil pressure sending unit on the side of the block. That usually does the trick.. Use teflon tape on it also...
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old February 8th, 2007, 12:53 PM   #4
chase's Avatar
1987 Mustang LX
So i got some advice and starting with the most basic fixes...first being checking the oil pressure sending unit. To my good luck the only problem was the wire was not connected completey. Thanks for the advice!!!
Old February 9th, 2007, 07:25 PM   #5
GTXRacing is on a distinguished road
Yeah mine is just the same... It's all Frayed to hell so I just cut the damn thing and spliced new wire into it and then added it to my new oil gauge and no more worries
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Threads Similar to: Problems With Oil Pressure Gauge... Need Help!
fuel pressure gauge dr.gonzo! 5.0 Mustangs 10 May 4th, 2010 05:12 PM
Oil Pressure Gauge Question Pastor J 2005 - 2010 6 September 6th, 2007 01:25 AM
Where is your fuel pressure gauge? (under hood) YNOT 5.0 Mustangs 7 June 25th, 2007 12:52 PM
Fuel pressure Gauge question. DrHolliday 99-04 5 June 2nd, 2007 03:46 PM
Mechanical fuel pressure gauge nolife 5.0 Mustangs 2 April 5th, 2007 12:19 AM
