Question about Seafoam
LinkBack (2) Thread Tools
Old August 20th, 2009, 11:51 AM   2 links from elsewhere to this Post. Click to view. #1
kalsador is on a distinguished road
Exclamation
I was wondering before I take my car to the nearest show. I wanted to seafoam it. Now I remember on my 2003 YZF 600R bike I would just place it in the tank and such and it would do it justice, but I keep seeing people putting it in the engine bay somewhere in videos on youtube. WTF doesnt that harm something. Let me know how to properly use seafoam if you could
Old August 20th, 2009, 12:31 PM   #2
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
put 1/3 of the can in your gas tank, 1/3 in your crank case through the oil neck on the valve cover, and 1/3 through a vaccuum line. I always used the brake booster line. do the vaccuum line first, pour about 1/3 in to a bowl make sure you have the engine to normal operating temp. before you start then have a friend with you start the engine and hold the vaccuum line over the bowl just dipping it in. and letting it suck up the sea foam little by little, have your friend hold the rpms or tap the gas just to keep the motor from stalling, and when you've got a decent little puddle left have your friend let off the gas put the hose in enough seafoam that it'll kill the engine. Next pour 1/3 in trhough the valve cover, and 1/3 in the gas tank. Let sit 10 mins or so then go start it back up. It'll smoke for a few mins but that means its working. Drive the car but change the oil with in the next 200 miles. Because in the crankcase it'll need to circulate to do its job but don't want it thinning out the oil too much or eating away at the detergents in the oil. Hope this helps.
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old August 20th, 2009, 12:31 PM   #3
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
1/3 of a can in the brake booster vac line. Shut the car off to let it soak for 5 min before the fluid burns off, then start it and rev at 2 grand for a couple of min.
Old August 20th, 2009, 01:00 PM   #4
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
NEVER do this.
you may end up hydro-locking your motor.
Old August 20th, 2009, 01:00 PM   #5
nolife's Avatar
91GT, 88GT, 02GT
Has anyone ever seen some before and after shots of the pistons and valves when doing this through a vac line? I'd like to see how effective it is.
EDIT:
I found one
Valve Cleaning with Seafoam
Old August 20th, 2009, 01:05 PM   #6
Traidmarx's Avatar
1995 Mustang GT
Originally Posted by R0B0T View Post
NEVER do this.
no you won't....
Old August 20th, 2009, 01:05 PM   #7
Traidmarx's Avatar
1995 Mustang GT
to hydrolock your motor you've have to suck about half a can of it up at once.
Old August 20th, 2009, 02:15 PM   #8
11.8@113...150 shot
to hydro lock your motor, you have to suck about half a can at once.
hm. real technical tech advice.
go ahead and kill your motor by flooding your cylinders with liquid, i prefer a method as simple as turning a key off.
also, do you know which cylinders it's getting sucked into? do you know the percentages of each cylinder in terms of air consumed(also seafoam)? do you know air (and sea foam) don't flow evenly through the motor?
quit giving shitty advice like telling people to kill their engines by sucking up enough seafoam to make it die. that's just retarded.
if you're sucking up so much seafoam that your friend has to keep the RPMs up to keep it from stalling, you're going to go through a 1/3 of a can in no time at all.
Old August 20th, 2009, 02:23 PM   #9
Traidmarx's Avatar
1995 Mustang GT
exactly no one said you were gonna spend 10 mins sucking it up.
as far as "real technical tech advice" sorry wasn't being specific enough on how he should go abou it if he wants to do damage to the engine. and as far as turning the key off method do you realize that in the time it takes you to turn the key off you're burning up most if not all of the seafoam in the motor? the point is to allow it to sit on top of the piston for a period of time to break up the carbon. I wouldn't give someone advice on how to do something that would mess their car up. I've done it 2 or 3 times on my car. As well as helped other people...
Old August 20th, 2009, 02:25 PM   #10
So Robot... Whats ur suggestion on where i should and how i should put the seafoam through the car. My friend who has worked on cars just said put it in the tank once a month.... but then i have heard some through the crankcase... and some through the brake booster line. Whats your suggestion
Old August 20th, 2009, 07:28 PM   #11
Where exactly is the Brake Booster line?? Does anyone have a picture of what it looks like i own an 89' mustang 5.0
Old August 20th, 2009, 09:21 PM   #12
neverfastenough1's Avatar
Attached to the Brake booster which is behind the master cylinder.
Old August 20th, 2009, 09:25 PM   #13
Brake boost line is fine. I had to use the pcv line because my car doesn't have vac boost.
Old August 20th, 2009, 10:10 PM   #14
EscortSportage's Avatar
1989 Mustang GT 5.0
wtf is seafoam ?
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old August 21st, 2009, 12:36 AM   #15
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
I put it through the "S" vac line off the tree. It goes straight into the manifold
Old August 21st, 2009, 01:04 AM   #16
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
Originally Posted by EscortSportage View Post
wtf is seafoam ?
Motor Treatment - Sea Foam
Old August 21st, 2009, 06:18 AM   #17
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
Funny thing is with my car I almost never get smoke. barley any. but with my truck or my girlfriend's there is always a HUGE smoke show!
why is this?
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old August 21st, 2009, 08:57 AM   #18
Traidmarx's Avatar
1995 Mustang GT
probably because you run yours harder than she does her truck...if you run the car hard on a regular basis carbon doesn't have time to settle on top of the piston.
Old August 21st, 2009, 11:18 AM   #19
What is the "S" Vac line.... could someone throw a picture up of the location of it.?
Old August 21st, 2009, 11:38 AM   #20
baine21225's Avatar
It's on the vacuum block
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/134364-question-about-seafoam.html
Hydro Brake Booster This thread Refback September 24th, 2009 03:12 PM
Question about Seafoam | 4dump.com This thread Pingback August 21st, 2009 10:50 AM
Threads Similar to: Question about Seafoam
seafoam question joejoe8455 99-04 25 February 11th, 2009 12:05 AM
seafoam question zinc02GT The Clubhouse 29 March 7th, 2008 12:28 AM
yet another seafoam question InSaYnE V6 Mustangs 3 February 11th, 2008 12:53 PM
Seafoam Question? CTown Stang 96-98 9 December 19th, 2007 01:02 PM
Seafoam Question silverbullet17 V6 Mustangs 5 December 12th, 2007 12:55 AM
