#41 |
1988 lx
9.68@142
no your heads and intake are not good for eachother..i had that intake and i was not impressed at all.
#42 |
E3, you think it is the Head and intake combo?
What intake would you recommend? Could the intake hold back the power that much?
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
#44 | |
1988 lx
9.68@142
try to put it to a base tune... how was your air/fuel? all cylenders fireing? take it to the track and see what it runs. there are so many vareables. what are your cam specs? what tranny you running?
#45 |
Spings are the ones that came with the AFR 185's...all parts are brand new.
Peak RPM before drop off was around 5700, i will post the dyno sheet when i get in thursday and tell you the specs from the cam....hopefully that will tell you guys something i dont know....it looked good and consistant to me with no sudden drop offs until peak RPM. But i didnt notice fuel/air numbers on the graph from the Dynojet...is this in small print or do i need to request this seperately? I even called Jasper to see if there was something different from the remanufactured HO 5.0's and stock and he said they are identical. I actually had to take the car back in Monday because it would not start when it got hot...the motor would turn over normally, but would not fire up..as soon as it cooled down, it starts right up...could this have something to do with it?
#46 |
T5 tranny
#47 |
1995 Cobra Convertable
[QUOTE=95project;2303212]Spings are the ones that came with the AFR 185's...all parts are brand new.
I'm not running your combo, but I do have AFR 205's I had to change my springs to match the cam. Their is a lot here to figure out but it kind of sounds like your choice of heads is a little big and your killing velocity |
#48 |
i have thought the 185's could be part of it..i think the 165's would work better now, but not in the future....my next step is 347 kit and then a SC, so i was trying to plan as best i could for the future.
#49 |
1988 lx
9.68@142
185's will be better did you notch the pistons for them?
the intake/springs are why the power dropps off that early
#50 |
we did not have to notch the pistons...the cam was very well thought out so we wouldnt have to
#51 |
mustangs rule....my 100th post.
#52 |
12.8@103... stock motor
11.8@113...150 shot
you really need to call whoever designed your cam, tell them where the power was being made/fell off at and see what they say...
#53 | |
1988 lx
9.68@142
honestly you should sell the AFR heads and buy some trickflow twisted wedge heads. and get a new cam made. you may be able to find someone to trade you heads. or when you have your 347 made make sure you buy the correct notched pistons and a new cam.
#54 |
thanks e3...i knew the heads i chose would not be exactly perfect for the setup now, but again i was trying to plan as best i could for the future. i think i will start saving for the 347 and just deal with it for now. i came so close to getting the twisted wedge heads, but felt that the afr 185's would be better in the long run.....But, i will still post the cam specs and dyno sheet when i get home tomorow
Threads Similar to: Dyno Poll
| Dyno Tune at Dyno Tuned Performance | CW5billwade | 99-04 | 18 | March 20th, 2009 01:48 PM |
| Do you believe Poll... kinda poll | JASonic | The Clubhouse | 30 | March 22nd, 2008 05:44 PM |
| Jan 19th Ft Myers - VMP Mobile Dyno - show, dyno runs and tuning by appointment | Justin00Stang | Southeast | 0 | January 4th, 2008 07:26 PM |
| Dyno Jet vs Mustang dyno | bransdaman78 | General Tech | 6 | April 2nd, 2007 05:23 PM |
| Mustang Dyno Global Dyno Day! | BadMoFo | Southeast | 1 | September 20th, 2006 04:09 PM |
