NEED HELP W/ 5.0 302 88 stang
Old August 21st, 2009, 04:36 AM   #1
McDoogle5.0 is on a distinguished road
This time in the right forum.
THIS POST WAS COPIED FROM A SIMILAR WEBSITE, AND DOES BELONG TO ME. TO FILL YOU IN, ABOUT A WEEK AGO I BEGAN EXPERIENCING A SURGING IDLE. MANY PEOPLE INSIST ON VAC LEAKS, AND MANY OTHER POSSIBILITIES. PLEASE READ THE POST[BOOK] ( its actually not that long... ) and help me decide what steps to take next. Thanks to you guys too, i know you will be able to add input.
SURGING IDLE CHECKLIST
-dirty/defective iab
-defective tps [not sure]
-vacuum leaks [not sure; sprayed carb cleaner around & no change in idle ]
-bad o2 sensors [replaced passanger side o2]
-insufficient voltage @ idle [not sure]
-dirty 10-PIN ( TEN PIN ) connector
-dirty/defective maf element
-maf element ( CAI SYSTEM )
-clogged fuel filter [changed;past 7 days
-bad grounds in computer controlled cars [not sure]
-dirty/defective ect and act sensors
-defective pcv'
-mistamatched aftermarket maf/injector sizes [No]
-vss sensor
-egr leaking or partially open [not sure]
I'd like to begin by thanking all who have contributed, and apologise ahead of time for the book of a post. The post contains photos, and videos of my mustang in a struggle against a surging idle / sudden loss in hp & driveability.
Beginning below are three (3) videos containg footage of the mustang in different phases, followed by a series of photographs of the journey, with questions and updates throught the post, and to come still.
BEGIN WITH A SHOT OF SOME TOOLS BEING USED SO FAR... nicee
PICTURE TWO CONTAINS A QUESTION REGARDING THE NAME OF A GASKET(S) LOCATED ON THE SECOND REMOVABLE PORTION OF THE THROTTLE BODY ( THE ONE CONTAING THE IAB ) FRONT AND BACK SIDE.
WOULD IT BE WORTH MY TIME TO UNBOLT THE IAB AND CLEAN/INSPECT?
http://img24.imageshack.us/img24/6392/deleteafter2.jpg
Its true when my buddy told me nobody was going to see all this cleaning up im doing, but i will im terrible at it so far and am going to get a few various shaped/sized buffer wheels and smaller flap wheels and get busy on this engine. one problem i have is the inside shell of the engine bay is coated with a protectant/goo to keep the metal shielded, but some of its comeoff/been scraped and i feel like removing it, and then sanding/painting the bay again / black
If theres something ive removed / messed with that i shouldent have or might try to later in this cleanup lemme know, haha
Heres a picture of before :
and another " BEFORE " general shot, boy does it look dirty in there.
ill put another video of the engine running from outside the car overhead the engine, its being processed by vimeo approx 1 hr from now.
if your actually reading all this crap.. than you've noticed ive completley taken apart the throttle body area/maf.. once again if this was dumb please let me know. I have ( the wrong ) gasket ordered and ready to be picked up in the morning, but since i have to wait i will do more cleaning up. I have no idea what those gaskets are called tho, and will try and figure it out tomorrow.
Here is what the inside of the throttle body looked like, after two or so hours of stripping the sticky corrupted... agonizing bad gasket from one side, while the other came off in almost one big piece, a few cracks inbetween. Did all the cleaning outside with an overhead lamp at 11pm, felt like James May [topgear] But I did all that with it still soemwhat attacted by EGR and springy throttle stick thingy/connector.
GAVE IT A BIT OF CLEANING. HA, A BIT. MORE LIKE THERE WAS A SLUDGE MONSTER LIVING INSIDE OF THERE! Millimeters thick along the edges of the spring moved plate inside of the body, black.. gunk.
Is this amount of dirt inside there normal? Sorry for all the questions and pictures.
Tell me if I'm stupid for gently using a 80-100 grit flapwheel sander with an electric drill.. I haven't " sanded " any threads or close to any edges/gasket holes. If I'm not criticized, i continue with the purchase of smaller ones to get into hard to reach areas.
I still need the buff wheel + compound but im pretty proud of this one, it was like really dirty at first.
Although the screw is rounded, and i want to get that fixed, for a surging idle i do believe number #2 : Defective / Dirty TPS.. so Im pretty sure i should pursue entrance to that sensor, even tho it means vices, punches and drilling the damn screw out...
Ive got a little bit more to share, but dont want to bore all of you with all the pictures and babble, but heres a few things ive asked througout the post and felt like updating it.
flopwheel sander on engine parts? yay or nay?
[ABOVE POST] how do i get the mechanic to compensate me / how to correctly threaten him with good " legal " jargan/claims.
Am i a retard? Was this a bad idea ( taking all of this off )
Anything to avoid cleaning / messing with ie: cleaning with toothbrush/wirebrush/wheel
Thanks for reading, and I have to remind you all, soon a second video contaning footage of the mustang being taken apart / t.b inspection / engine area video, will be avaliable to watch as soon as it is done rendering. ( about a half hour from now )
So here are videos of the engine running at idle, a close look at the tps/iab/throttlebody/mass air.. and engine running at idle overhead engine view instead of inside the car. pretty good sound if you turn the speakers up, hope some of you GURU's can tell me just by listening. videos run 19, 60 and is shot from overhead the engine.
REPAIRS IN PAST 7 DAYS:
BEGAN ENGINE CLEANUP OPERATION
REPLACED PASSANGER SIDER EXHAUST o2 SENSOR
REPLACED FUEL FILTER
REPLACED OIL FILTER & OIL
REPLACED ALL SPARK PLUGS
REPLACED MANIFOLD SET ( REPAIR SHOP " SUPPOSEDLY" DID )
REPLACED WIRE SET??? ( REPAIR SHOP .. )
REPLACED DIST CAP AND ROTOR ( AGAIN, SHOP )
REMOVED THROTTLE BODY ALLTOGETHER FOR INSPECTION & CLEANING
TO DO;
FINISH CLEANING T.B AND COMPONANTS; FIGURE OUT THE NAME/ID# OF THE TWO GASKETS I NEED, AND ANY GASKETS I MAY NEED IN THE FUTURE IF I CONTINUE UNBOLTING THINGS TO CLEAN THEM.
REPLACE GASKET
& START WITH NO SURGED IDLE FOR THE LOVE OF ALL THINGS GOOD.
BLOG/UPDATE COMPLETE.
Old August 21st, 2009, 08:26 AM   #2
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
did you look at the sticky in the main 5.0 forum on idle surging?? check it out
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old August 21st, 2009, 09:39 AM   #3
BORDEN's Avatar
91 lx convt
14.02@100
BORDEN is on a distinguished road
+1 that info saved me a lot of hassle
Old August 21st, 2009, 09:44 AM   #4
aka Nature boy
sickfox's Avatar
I like turtles
oh yeah and i have two sets of those "Salt and pepper shakers" so if you do dont forget to do both!
www.xjor.org
Old August 21st, 2009, 12:21 PM   #5
95StangMX's Avatar
95 Mustang GT
man that thing looks like you pulled it out of the bottom of a lake! No offense its just REALLY dirty....good luck on the cleanup/fixing
Old August 21st, 2009, 07:37 PM   #6
I have the surging idle checklist in this post :p
I NEED to know what the name of the gaskets is in picture two, or even what that " block " is called so i can get the gasket.. two days in a row napa has supplied me with the wrong gasket.. i even took pictures into them high quality and there like we can order it but no...
2nd picture down ( 5th including movies )
Old August 21st, 2009, 09:14 PM   #7
neverfastenough1's Avatar
EGR and throttle body gasket.
Old August 21st, 2009, 09:31 PM   #8
What were the gasket part numbers they gave you? According to their web site, FPG 70262 is the part# for the throttle body to egr spacer gasket and FPG 72543 is the part# for the egr spacer (that "block" you highlighted) to plenum (upper intake) gasket. Hope that helps.
Old August 24th, 2009, 07:09 AM   #9
Thanks guys, i have to wait until 7 or 8 - to go and pick up the gaskets so i can put everything back on and see if its working better.
I ordered a upper intake gasket for six dollars, should i/ would it be worth it to clean that out?
Thanks!
Old August 24th, 2009, 07:10 AM   #10
Yeah, no joke.
Do you think sandblasting would work against this grime?
Any ideas?
Threads Similar to: NEED HELP W/ 5.0 302 88 stang
Engine Swap, '95 302 into a '70 302 Altumdreams Classic Mustangs 2 February 15th, 2009 11:09 AM
302 HO in a 03 v6 stang niners2046 Modular Mustangs 4 November 10th, 2007 06:16 PM
Help carb'ed 302 /efi 302 sins23 5.0 Mustangs 5 September 10th, 2007 09:26 AM
1968 stang with 1991 302. Easy or difficult? red-68-mgt Classic Mustangs 4 July 12th, 2007 11:08 AM
Weight of Dart sportsman 302 compared to stock 302 painfully slow 5.0 Mustangs 3 February 23rd, 2007 04:47 PM
