'93 Fox HB Door problem
Old August 21st, 2009, 10:35 AM   #1
haveav8's Avatar
1993 Mustang LX
haveav8 is on a distinguished road
Driver side of my '93 HB Fox Have to slam door extremely hard to get it to close,
any ideas. Thanks
Old August 21st, 2009, 10:57 AM   #2
nolife's Avatar
91GT, 88GT, 02GT
Either the door is hanging low because of worn hinges or your latch striker needs to be be adjusted to mate up with the latch better. If it shuts easier when you are lifting up on the door, it is more of a hinge problem. If not, I'd play with the striker position or maybe consider getting a plastic sleeve for it.
Old August 21st, 2009, 11:39 AM   #3
baine21225's Avatar
By hinge do you mean bushings? I'd say that or latch/striker
Old August 21st, 2009, 12:48 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
Yes, I considered the bushings a part of the hinge
Old August 21st, 2009, 01:05 PM   #5
haveav8's Avatar
1993 Mustang LX
Thanks for the responses,
The latch plastic is somewhat worn, where can I get a replacement? Wait Latemodel has them.. ha ha
The door does lift a little, so how do I adjust or repair the hinges?
thanks
Old August 21st, 2009, 01:07 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
They all lift a little, does it shut easier when it is lifted?
Old August 21st, 2009, 01:24 PM   #7
haveav8's Avatar
1993 Mustang LX
No it does not, tried several times but it's same.
It does close a little better with window down,
don't know if that means anything.
Threads Similar to: '93 Fox HB Door problem
SN door panels in FOX RaceRelated 5.0 Mustangs 1 August 16th, 2007 10:14 PM
