1991 mustang 5.0
Want my car to handle..
So, I thought taking the front sway bar off was cool and I wanted to make my car a drag car. But now I changed my mind. I want my car to handle turns and stuff better. I ordered new energy suspension bushings for my front sway bar tonight and they should be here in a couple days. Now, I noticed lately I'm getting some wheel hop. More than it used to. I want to get some control arms. What would you guys recommend? I've heard the Summit brand box style were nice? I want to do all this on kind of a budget. I don't need top of the line stuff. Just wanna make my car handle better than stock.
I also want to do shocks/springs. I was thinking eibach prokit for springs and I have no idea for shocks and struts. I originally wanted 50/50's and 90/10's but I don't want a drag car anymore. Would Caster/camber plates be needed with these springs? I think its a 1.25 drop or something like that. Also, I think I should do subframe connectors. How much would it cost to get these welded on average? Could I just do the bolt in ones and get them welded later on? And is there any benefit from a strut tower brace? |
aka Nature boy
blk 89/red 91 XJ Limited
I like turtles
I dont remember who posted the thread but someone on herr jsut bought some uppers and lower arms for like 119$ on ebay and were almost like the ones summit brand offers. he said that he recommends them. If i find it i will post it in here.
that was me and there are the same exact ones as summit. they ship to you in like 3 days and install was a breeze,just pb blast all your bolts. i summited a best offer to them ang got them for 135 shipped
control arms
you dont need no teef to eat my beef Last edited by fl4321; August 22nd, 2009 at 12:07 PM. |
1991 mustang 5.0
nope got everything fixed. runin goooood
1989 Mustang GT 5.0
tokico for struts, they offer different kinds for our cars, i have the 5 way adjustables (Illumina)
camber caster plates are a must, and front strut braces are cheap and effective and subframe connectors are a must,
10 point Cage Bunch of newer mustang parts Maximum Motorsports catalog Sparco stuff "a huge bad azz motor is nice untill you have to turn or stop" Last edited by EscortSportage; August 22nd, 2009 at 06:02 PM. |
#7 | |
1991 mustang 5.0
Also, I got some Moog bushings for my front swaybar. Anyone know if they are poly? If not, I'm just gonna run them until I get money for a full bushing set, Energy Suspenion or Prothane... I ordered Energy Susp sway bar bushings at Checker the other day but today they told me they actually don't carry them at all anymore so I went with Moog for now. Saved me 5 bucks but I might replace later down the road. |
Priest of the Car Gods
If I were on a tight budget, this would be my setup. Go as far down the list as you can afford, and yes, these are in order.
SFCs - don't waste your time with bolt-ins, unless you bolt them in and immediately drive them to a shop to be welded in. Good front brake pads - Hawks, EBCs, or my preference, Porterfields. Good brakes allow you to carry speed longer. Tokico blues. Not the best shock, but cheap and able to handle a stiffer spring. Maximum Motorsports CC Plates. Yes, before you even lower the car, get CC plates. For a handling car, you NEED a performance alignment, the stock setup only allows for toe adjustment, and yes, do this BEFORE springs. For the alignment - Go for 0 toe (straight up), dial in as much positive caster as you can (try to get at least 4 degrees), and I'd start with 1 degree of negative camber and adjust based on tire wear. H&R Springs, whatever flavor suits your fancy. Get another alignment after installation. Panhard bar. Yes, I would do this before LCAs, though ideally you'd do both at the same time. The rear end wiggle is very confidence-sapping, and ruins the predictablility of the car at the limit. LCAs - get the kind with at least one spherical joint if you can't afford the kind with spherical on both ends. If you've got both good LCAs and the panhard bar, remove the driver's side UCA and the quad shocks. The last thing I'd do is fine tune your swaybar setup. If the car is understeering, stiffen your rear bar (or soften your front setup). If it's oversteering, soften the rear (or stiffen the front). If you've lowered the car, you may want to get shorter or adjustable front swaybar links to get rid of the swaybar preloading that will occur. This setup will run you maybe $1k if you buy everything new, and you'll be able to outhandle most Mustangs on the road at that point.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
1991 mustang 5.0
Awesome dude thanks for the write up!
1989 Mustang GT 5.0
why would u wanna remove the upper control arm on the drivers side/and quad shock on driver side as well,
i cant wait to install my tokico illuminia's there are 5 way adjustable and should be fun tuning them for different occasions.. heres my thing u dont want to spend all this money on stuff if in the end u will change the stock k member for an after market one, cuz then ud probably go to a full coil over conversion, and u can convert the rear to coilovers too. so like i said b4 do lots of homework
10 point Cage Bunch of newer mustang parts Maximum Motorsports catalog Sparco stuff "a huge bad azz motor is nice untill you have to turn or stop" |
#11 | |||
Reason for removing the quad shocks: The quad shocks are a band-aid that Ford installed to try to control wheel hop. In effect, they're extra control arms that add bind to the system. If you replace the stamped steel LCAs with tubular or boxed units, you no longer need the bandaid. I pulled the quad shocks out of my fox after installing some MM LCA, and the improvement in ride quality alone is worth it. Reason for removing the driver's side UCA: The UCAs are there to do two jobs: 1)lateral axle location and 2)prevent axle wrap. In stock form they do neither job very well, but are especially bad at lateral location. The job of a panhard bar is lateral axle location, so once installed, you only need the UCAs to prevent the axle wrap. You don't need both to do that, and removing one frees up some bind that is inherent in the triangulated four link setup. This combination of panhard, good LCAs, and passenger side UCA is commonly referred to as the "poor man's 3-link". My feeling is that if you're messing with shock settings, you're not learning to drive the car; you're trying to adapt the car to your current level of driving technique. To me, this is "blaming the car" for being slow and doesn't help you to become a better driver. Rather than going "I understeered, so I need to soften the fronts 2 clicks", look at what input you gave the car and change that first (maybe you came in too hot, or you didn't have the weight balanced, or you had overcooked the tires on the previous few corners, etc).
1991 mustang 5.0
Well, I put the front sway bar back on today with some new bushings and HOLY SHIT! Night and day difference. My bushings were worn out before so I just took it off and didn't notice a difference. But now after putting it back on with some new bushings, it feels like a different car. I love it.
So, should I only worry about Lower control arms? I don't need to change out both? If I just got some good boxed lowers I could take out the quad shocks finally and have no wheel hop even with the stock uppers? I ask because I want to do control arms next. Then shocks/CC plates and sf connecters |
#13 | |
Regarding UCAs, if you wanted, you COULD do good LCAs, skip the panhard bar, and then get UCAs with spherical joints on both sides. This would give you the best version of the stock 4-link setup, and assuming you got adjustable uppers, seems to be a popular setup with the drag racing crowd. Personally, I think this is a waste, though, as you still have most of the issues of the stock 4-link, just with less bind. In the end, this is your car, and your money, so do what works for you.
#14 | |
1991 mustang 5.0
1991 mustang 5.0
What LCAs are good? I was looking at Summit brand and Maximum Motorsports brand. Recommend me some good ones for a good price? Also, boxed or tubular? This is a street car
I like Maximum Motorsports stuff. Decent price, good quality. I don't honestly believe boxed or tubular really matters, just so long as it's not stamped, hahahah. More important is the bushing material - make sure at least one side is a spherical joint (the MM units are spherical on the axle side and poly on the chassis side - this is a good setup for a street car as it frees up the bind, but limits the amount of noise transmitted into the chassis).
1991 mustang 5.0
Alright cool. I'll go with the MM LCAs. But If I get just LCAs, can I remove the quads and have no wheel hop? I found the Tokico blues on latemodelresto. And is there any difference in handling with H&R springs and Eibach springs? Should I get just get lowering springs or some road race ones? Or does it matter? Which H&R springs should I get if I choose those? They have no description soooo....
#18 | |
I'd probably go with either the Super Sports or the Race springs, depending on how serious you are about your handling. Having never ridden in a car with either, I can't speak to empirical knowledge of their ride quality, but I feel safe saying that the Race springs will have a harsher ride.
1991 mustang 5.0
Ahh ok thanks for the info. I want just a little drop like 1.5 inches. I'm either gonna go with the Eibach Prokit or the H&R super sports... I want a comfy ride lol. Thanks. Reps
Threads Similar to: Want my car to handle..
| I guess not all car makes can handle real power... | 1FastFox | The Clubhouse | 6 | August 5th, 2008 01:02 PM |
| how much will it handle? | droppedbass87 | 4V / SVT | 30 | May 12th, 2008 10:14 AM |
| which will handle better? | Steve O | General Tech | 3 | October 4th, 2007 05:49 PM |
| Need to HANDLE HP | trueballerisme | V6 Mustangs | 64 | June 18th, 2007 11:51 PM |
| can it handle it? | 9stang1 | 5.0 Mustangs | 10 | December 15th, 2006 05:52 PM |
