HELP!! Frustrated 5.0 owner ready to part out - Page 2
Old November 27th, 2009, 01:46 PM   #21
JBIGBOOTSY's Avatar
1990 LX hatch
if it runs check for codes.
Old November 27th, 2009, 09:51 PM   #22
1991 Mustang 5.0
WDfrmTN has a little shameless behaviour in the past
Originally Posted by Catori View Post
Sorry for the long delay in getting back with results.
So - took the MSD module off of the distributer, tested at Advance and was bad. Bought a new Ford module and put it on MSD distibuter. Car fired right up - drove it for a bit and parked it. Went back about two weeks later - started right up and warmed up fine. Two weeks more - drove it onto a trailer - brought it home. Started it up to back off of trailer - car died when idling - would not restart. Obviously frustrated - backed it off trailer using starter motor - using clutch to control speed - car refired and I backed it off trailer. When pulling forward onto pavement - car died again - would not refire. Used clutch and starter to move to driveway - car wanted to restart and did. Drove it down road and back. Parked it. Went back two weeks later to start and warm up - would not start. Went back today - turned over slowly - fired up and ran. Let it warm up and idle for a while - car died once again - will not restart.
Thought it might be the clutch switch -was going to change - but I do not see how that would cause it to die when it is idling in neutral with the clutch pedal out.
Thought I had it fixed by replacing the module on the front of the distributer, no luck. Just an FYI - it first went out with the Ford distributer installed.
Ideas?
Wiring issue, most likely:
Salt & Pepper Shakers
Mustang FAQ - Engine Information Check the injector harness from the EEC to each injector. Do continuity and resistance checks. Also check for a ground (which you shouldn't have) from each pin.
EEC power relay, above EEC in RH kick panel (remove glove box).
A bad fuel pump won't turn off your injector signals, BTW.
"Seek to understand before you seek to be understood."
Unknown
"Life's tough...it's even tougher when you're stupid"
John Wayne
Old November 28th, 2009, 01:59 AM   #23
odie22's Avatar
86 Ford Mustang
odie22 is on a distinguished road
put an intake and carb on.... that will fix it
Old November 28th, 2009, 02:16 AM   #24
The Razor's Edge
White Thunder's Avatar
you took the words out of my mouth
founder of the FTN Club
Threads Similar to: HELP!! Frustrated 5.0 owner ready to part out
I'm frustrated G.T. Rags The Clubhouse 40 July 5th, 2009 09:20 PM
Rx-8 owner ready to become a GT owner leebunnyz 2005 - 2010 60 February 2nd, 2009 10:58 AM
frustrated 05stanggta The Clubhouse 25 March 8th, 2008 09:51 AM
i am frustrated! blazor V6 Mustangs 30 October 20th, 2007 04:19 AM
frustrated zero 5.0 Mustangs 49 May 3rd, 2007 10:08 PM
