HELP!! Frustrated 5.0 owner ready to part out
Old August 22nd, 2009, 09:56 AM   #1
Catori is on a distinguished road
Have a '93 GT that will not start. Have sought help before and nothing seems to work.
The problem: car will not start - turns over very strong - the electricity pulse to the fuel injectors is being cut out by something - confirmed by noid light. This is why the car won't start - no pulse to the injectors to put in fuel - car will briefly fire up on starter fluid - but will not run because of injector deficit.
What usually works is to cut the electricity to the car by pulling the battery for a period of time. If it chooses to start after this fix, then it will cut back out after idling for about 3 minutes - then it will not start again. You can also pull the ECU for a bit and it might work - but again, only for a short time.
What's been tried: has a new fuel pump, new pump relay, new MSD distributer, new fusable link that runs in the electrical line for the fuel system, new throttle position sensor, new tfi coil - none of these worked - replaced the ECU/computer and this fixed it for a about a day - then the problem re-occured.
Someone suggested that it may be a ground that is kicking the injectors off - anyone have a diagram of the location of the engine and harness grounding points?
ANY IDEAS APPRECIATED!!!
I have over $9500 invested in this car and am about to trash it.
Thanks for the help.
David
Old August 22nd, 2009, 10:07 AM   #2
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
Have you pulled the codes with this test or is that the noid light you talked about?
DIY KOEO/KOER/Cylinder Balance Self-Test Procedure
Old August 22nd, 2009, 10:49 AM   #3
Yes
Pulled codes just about every time - reason for replacing the throttle position sensor and I replaced the air intake temp sensor due to a code.
The electrical cut out for the injectors does not show up as a code.
Thanks for asking - greatly appreciate the help.
David
Old August 22nd, 2009, 10:57 AM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
im thinking that you have an intermittent short somewhere. You should try doing a continuity test from each of the wires on each of the injectors and to the ecu.
BUILD 2 IN PROGRESS
Old August 22nd, 2009, 11:09 AM   #5
fl4321 is on a distinguished road
i need 1/4 windows
you dont need no teef to eat my beef
Old August 22nd, 2009, 11:16 AM   #6
1998 Cobra
13.24@105.66
sounds like a bad ecu to me...
Had similar problems with nissan ecu's crapping out with lousy injector pulse
weeee foooord!
Old August 22nd, 2009, 11:19 AM   #7
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
yeah ECU sounds right but he mentioned that he replaced it which leads me to think that it is an intermittent short. I mean, even if it is a used ECU whats the chances of the same problem occuring on a different ECU not to mention that he said it fixed it for a day and then it came back.
BUILD 2 IN PROGRESS
Old August 22nd, 2009, 02:02 PM   #8
1986 mustang gt
1fst5.0 is on a distinguished road
check all your grounds, and youre probably gonna have to go through the wiring. also, the hall effect sensor in the distributor needs to be checked too, not just the module.
Old August 22nd, 2009, 08:11 PM   #9
94bonestocker's Avatar
1983 LX Hatch
94bonestocker is on a distinguished road
Possibly the Fuel Pump Cutoff Switch is intermittent? You know the one that trips in an accident. Try Tapping on it and see if it trips.
Whats your fuel pressure?
Edit: Nevermind, just re-read your post stating the power to the injectors is dropping.
Just your everyday Non-5.0L LX Fox
Old August 22nd, 2009, 10:09 PM   #10
1983 LX Hatch
Ok, So after looking at the wiring diagram that TMoss has on a different website, it shows that the + side of the circuit comes right off of your ignition switch via the Red wire. The - side (or the Ground if you wish) is coming from the ECU which it looks like it just gives the injector when it wants it to squirt. From the diagram it shows that the ground for the ECU comes from several pins, Black wires 20, 40, 60, and an Orange wire on pin 49. Which one is for the injectors is anyones best wag.
So this is what I would do to narrow the possible problems.
1. Check that power is coming into the injector harness with the key in the on position via the red wire. It shold be powered at all times when the key is on. Check it either with a multi-meter or a "probe" style checker light thingie. I can't for the life of me remember what they call it.
2. Measure the ohms from the pins (disconnect the main ecu plug and measure the plug side, not the computer side) I stated in my main post (20, 40, 60 and 49) to ground. I can't believe the reading would be over 1 ohm. If any of the readings are higher, trace the wire to where it attaches to the chassis and see if it's heavily corroded or a broken wire. Fix any if the readings are to high. Of course if you found a bad ground try seeing if that fixed it before continuing on with the next step.
3. Connect a jumper in line from the + side of the battery to the Red wire feeding the injector harness. Make sure to connect it in parallel with the existing harness. What this does is tell you if it's a + power issue, or a ground issue. If you get this far and this jumper fixes it you have a bad power wire and more than likely it's heating up after a few minutes and killing the + to your injectors.
Of course this is all going on the fact that the Wiring Diagram that I'm quoting is correct.
As always if you find the problem please post back as to what it was for the future people searching this thread looking for an answer.
Good Luck!!!
Old August 22nd, 2009, 11:21 PM   #11
Thanks!!!
To all that have replied - THANKS for the thoughts/ideas. Will try these things tomorrow and see what I can find.
Bonestocker - thanks for the detail in your post - helps a lot to narrow the focus.
Will post results once I have tested these ideas.
Take care.
David
Old August 22nd, 2009, 11:55 PM   #12
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
ignition starter switch is probably less than 20 bucks , take probably less than an hour to install it on the column , Id try that before I even broke out the test light , if that doesnt fix it , take that crap MSD distributor out and put in an OEM replacement one and try that next ....the MSD dizzys have a high failure rate to say the least
Old August 23rd, 2009, 01:04 AM   #13
1983 LX Hatch
Please report back on the fuel pressure as well. If the injectors don't have enough fuel pressure they won't fire.
Old August 23rd, 2009, 05:40 PM   #14
86er's Avatar
TFI? module
Just a truck
Old August 23rd, 2009, 06:39 PM   #15
scottmach's Avatar
2011 Mustang GT premium
scottmach is on a distinguished road
Mine lasted all of 200 miles before I put the stock one back in today. That wasn't too bad though as my Summit one never worked out of the box. Back to the stocker and lesson learned.
2011 Mustang GT Automatic
Kooks catback, Lethal off road H-Pipe, BMR lowering springs, BMR lower control arms, BMR relocation brackets, BMR adjustable panhard bar, JLT CAI, VMP tune
2003 Mach1 Sold
2.3 Whipple @ 25 lbs. 718 rwhp/735 rwtq
Old August 23rd, 2009, 09:17 PM   #16
e3sean's Avatar
1988 lx
9.68@142
the ecu ground is right where the harness plugs into the computer there is a ground then the fuel injector harness has a ground that should be going to the block and there is a grounding strap that goes from block to firewall.
also try a new ecu relay and maybe bypass the inertia switch for the time being.
just hook up a fuel pressure gauge and if u have good fuel pressure and you have spark when it dies then its a short in the harness.
<font size=4><b>MILITARY CREW
Old August 23rd, 2009, 10:31 PM   #17
PONYMAN's Avatar
PONYMAN is on a distinguished road
Send a message via Yahoo to PONYMAN
Question
Went through that with my Fox.
Turned out it was a bad fuel pump & the mechanic was at it ,he cleaned out the tank.
Have you driven a Ford lately ?
Old August 23rd, 2009, 10:34 PM   #18
BoostFiend's Avatar
'03 Cobra, '89 +'91 Notch
11.63@120.08, Cobra
BoostFiend is on a distinguished road
+1 although not on a Fox, I had a brand new Walboro 255 that would cut out as soon as the car warmed up. If I waited a few hours i could get it to fire up but it wouldnt' stay running.
Old August 23rd, 2009, 10:56 PM   #19
1998 Cobra
13.24@105.66
Just fyi when testing injectors.. it's a continuity test, not voltage test. The ecu controls the ground circuit (-) and when the 'pulse' is sent, the solenoid (injector) fires
weeee foooord!
Old November 27th, 2009, 12:47 PM   #20
Sorry for the long delay in getting back with results.
So - took the MSD module off of the distributer, tested at Advance and was bad. Bought a new Ford module and put it on MSD distibuter. Car fired right up - drove it for a bit and parked it. Went back about two weeks later - started right up and warmed up fine. Two weeks more - drove it onto a trailer - brought it home. Started it up to back off of trailer - car died when idling - would not restart. Obviously frustrated - backed it off trailer using starter motor - using clutch to control speed - car refired and I backed it off trailer. When pulling forward onto pavement - car died again - would not refire. Used clutch and starter to move to driveway - car wanted to restart and did. Drove it down road and back. Parked it. Went back two weeks later to start and warm up - would not start. Went back today - turned over slowly - fired up and ran. Let it warm up and idle for a while - car died once again - will not restart.
Thought it might be the clutch switch -was going to change - but I do not see how that would cause it to die when it is idling in neutral with the clutch pedal out.
Thought I had it fixed by replacing the module on the front of the distributer, no luck. Just an FYI - it first went out with the Ford distributer installed.
Ideas?
Threads Similar to: HELP!! Frustrated 5.0 owner ready to part out
I'm frustrated G.T. Rags The Clubhouse 40 July 5th, 2009 09:20 PM
Rx-8 owner ready to become a GT owner leebunnyz 2005 - 2010 60 February 2nd, 2009 10:58 AM
frustrated 05stanggta The Clubhouse 25 March 8th, 2008 09:51 AM
i am frustrated! blazor V6 Mustangs 30 October 20th, 2007 04:19 AM
frustrated zero 5.0 Mustangs 49 May 3rd, 2007 10:08 PM
