1988 lx t-top
ported stock heads
how much can I port the stock heads on my 88 and what kind of hp increase can i expect......i dont have any money for new heads so i have to do it my self.
11.47@120.58
15 hp or so, maybe 25 with bigger valves. Will help any cam or intake mods produce better though. Blend the bowls to the ports, remove the smog bumps from the exhaust, gasket match, and smooth out the casting flaws. No need to try and make the ports any bigger with the stock valves. If your gonna go to bigger valves you can get alittle more aggresive removing material. Your not gonna outflow an aftermarket set though, so keep that in mind.
these could help u i dit it a some time back and i felt the difference i use a felpro gasket to port mach the heads to the intake and headers but be real careful and listen to make sure that u dont cut into a colant passage it will make a high pitch sound as u get close to them
Head Porting Info
![]() SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$% |
1999 Ford Mustang V6
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
1988 lx t-top
sounds like alot of work for such a little gain. what year explorer came with the steel gt-40 heads not the gt-40p
I know for sure that at least the '97 Explorer had the GT40's. I'm not positive on the others.
1988 lx t-top
gt40 or gt40p and how do you tell?
are we all just going to have to come up there and do a thrash on the car for some hp's?.....I'll be on a raod trip next weekend to vist someone anywayz
#9 | |
Generally, you need a special set of headers to fit the GT40p heads. If you're just looking for a decent flowing "stock" head, the p's are actually a little better than the regular GT40's. HOWEVER, if you're going to have any work done on them...And you probably should if you're going to buy a set of used ones. They'll generally need a valve job, or at the very least be cleaned up. And then you'll need a valve job anyway. Then your best bet is to go with the non "P" heads. |
Threads Similar to: ported stock heads
| PI heads vs ported non pi | stanglifemike | 96-98 | 2 | January 21st, 2007 02:25 AM |
| ported heads | coreyfitz | 5.0 Mustangs | 0 | January 9th, 2007 11:25 PM |
| Ported heads | tlgrant | 99-04 | 7 | December 12th, 2006 02:55 AM |
| Ported PI Heads Yesterday | mdvaldosta | 99-04 | 9 | October 31st, 2006 02:11 AM |
| CNC ported heads (split-port) | 99mustang232 | V6 Mustangs | 2 | August 7th, 2006 09:56 AM |
