Trick Flow Track Heat Kit
I have installed the Trick Flow Track heat kit, .499/.510 cam, twisted wedge heads, upper and lower Track heat intake, double roller timing, 90mm MAF, roller rockers. Now that I have it all installed i can't get the car to start. I checked the injectors they are all spraying fine. I checked to see if all pulgs were getting spark, they are fine. I have everything set to t.d.c. The only thing is now my battery is kinda cranking the motor slow. So today I am going to try jumping it w/ another car while I try to start it. I am not real good w/ timing. Has anyone installed this kit or had problems starting their 5.0 after a tear down?
RIP Justincredible! God Speed
Make sure your distributor is on the #1 plug @ TDC of the "compression" stroke.
Its a common mistake to time it at the TDC of the "exhaust" stroke. (aka 180 deg. out of time) Also check to see if your fuel pump is turning on.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
Isn't the number 1 plug closer to the interior of the motor on the cap? For a 93 5.0 So on t.d.c. the rotor should be pointing towarrds the firewall?
#4 | |
Now that I have it all set right, I got it to fire once and it was God afull loud. I pulled the spark plugs and i could dump gass out of the plugs. This can't be good?
Is the fuel pressure regulator hooked up to a manifold vacume source?
Is the mass air meter calibrated for the injector size your using?
yes the fuel regulator is hooked up, I had to install some connections for it on the new upper plenum. I bought a 90mm MAF that is suppose to be calaberated to 19# injectors. I will check the box to make sure the did calaberate it to the right size.
Threads Similar to: Trick Flow Track Heat Kit
| Trick Flow Track heat valve springs? | Tony_90fox | 5.0 Mustangs | 2 | June 23rd, 2007 01:31 PM |
| Trick Flow street and track heat | shurb125 | 5.0 Mustangs | 3 | June 11th, 2007 10:43 PM |
| gt 40 or trick flow? | 95wip | 94-95 | 8 | April 21st, 2007 10:42 PM |
| Trick Flow Track Heat Top End Kit | shurb125 | 5.0 Mustangs | 4 | April 19th, 2007 11:31 PM |
| Trick Flow Street Heat | stang94 | 5.0 Mustangs | 25 | December 11th, 2006 11:34 AM |
