'03 Cobra, '89 +'91 Notch
11.63@120.08, Cobra
Finally some attention for my '91 Notch.
Ok so my plans for doing some work on my '91 were recently put on hold as I was forced to DD her a bit (turned from 78k to 81k
) while my Cobra was in the shop and I had just sold my former DD. My Cobra will be finished this week so I will have some time to do some much anticipated modding/maintenance on my Fox. I have H/C/I planned but thats for this winter.So far here is what I have in the works. 5 lug conversion with rear disc. (Using the brakes from a '90 LSC) Reinstalling my rear seat and seatbelts Oil change A good wax, wash. and detail Reinstall my battery under the hood (Its still mounted in the passenger side rear floorpan where the former owner put it?? )Install my 3.73's with correct speedo gear Anyone have any input as to other semi easy/fast stuff I can do while the car will be down? I am trying to locate a good short shifter and possibly an o/r H or X pipe if I can find a good deal. I was also thinking fuel pump and filter? I am also at odds of what wheels to run. I have an extra set of 10th Anniv. wheels but they are 17x9 and I know they don't fit without some issues. Thanks in advance for input.
11.63@120.08, Cobra
Guess nobody has any ideas? lol I thought about it today and also decided to add some weld in FLSFC's.
#4 | |
add some struts and shocks to that list. im sure as old as the fox is it wouldnt hurt. also ive always been under the impression a 17x9 wheel would fit just fine it depends on the tires size you put on them
![]() 87 Notch Doing a lot with a little _____________________________ lightweight, stock motor, and 12's? |
1983 LX Hatch
While you've got the time and the welder out for your subframe connectors, box in your LCA's or purchase a decent set of aftermarket ones and also put in some battle boxes.
Just your everyday Non-5.0L LX Fox |
#6 | |
11.63@120.08, Cobra
94bonestocker - Thanks for the idea, I had forgot about doing that too. Also thinking of adding a firewall adjuster and clutch quadrant. Guess I should have posted a mod list. lol
11.63@120.08, Cobra
Eibach pro-kit lowering springs
KYB gas-a-just Shocks/Struts Complete Energy Suspension master bushing kit Energy Suspension motor mounts BBK shorty headers BBK X Pipe with cats Pypes stainless cat-back BBK fenderwell cold-air intake BBK UDP's FRPP Master Clutch Kit with aluminum Flywheel 140amp alternator Thats what the car has done currently as far as aftermarket stuff. Oh and I just replaced the cap, rotor, and plugs.
#8 | |
89mustanglx5.0
the clutch quadrant was one of my first mods. I have a BBK I beleive...
looking for a mustang again.! |
11.63@120.08, Cobra
Battle box is a kit for reinforcing your torque boxes. Helps alot.
#10 | |
1983 LX Hatch
![]() They are a necessity when running slicks or sticky tires and a little bit of horse power as they stop your floor from cracking and the LCA's from tearing out. I actually just made my own and when I pulled the rear seat and carpet out of the way to weld in the new top plate, both sides of my floor was already buckled, and underneath the Drivers side torque box was already bent up pretty bad. The funny thing is I haven't even ran slicks yet and I only have P-zero's for tires.
You could turn up the timing a little bit depending on what fuel you are using. It will help out in the power department a little bit.
you don't need more of a fuel pump with those mods, put the money towards something else and without a doubt get subframes.. these cars should have come with them stock and it doesn't matter if you want full lenght, through the floor or normal short style as long as you put some type of subframe on. Of course full lenght is better then the short style and throw the floor is best but not all cars require you to go all out in this area.
11.63@120.08, Cobra
I realize I dont' need a fuel pump now but I will be doing a H/C/I swap with 24lb injectors this winter so I figured it might be smart to get that out of the way.
1992 Mustang GT
Coming soon...
A set of control arms would be a good investment as well. Id recommend subframe connectors, torque box reinforcements, and control arms.
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work |
yeah I would do the 255lph fuel pump and a new filter. also look into an SCT chip for future dyno tuning. I would set the timing to about 14* and run premium gas and see how it likes it. I run 17x9 in the rear with 275/40/R17 tires and they fit with a little modifications to the wheel well to ensure there is no rubbing. I run 17x8 up front with perfect fitment
Threads Similar to: Finally some attention for my '91 Notch.
| Finally got some wheels on my notch | BigBlockFairlane | Pictures | 7 | March 28th, 2009 05:32 PM |
| First of all Attention Ah ten tion!!!!! Attention | WAR-PARTY | The Clubhouse | 0 | March 18th, 2008 07:11 PM |
| Finally, Some Mustang Attention! | HPDE | The Clubhouse | 1 | August 7th, 2007 08:07 PM |
| Because I need attention... | Gunny | 2005 - 2010 | 3 | August 19th, 2006 10:11 PM |
