LinkBack (1) | Thread Tools |
#1
1988 Mustang 5.0 LX
12.48@118.27
Idle surge after fuel pump change
I had a bad Idle because I was told I had a bad fuel pump. the fuel pressure was sitting at 10 psi and I changed the fuel pump to a carter fuel pump that I bought at kraigen and I helped but it didn't fix its Idle problem what could it be
aka Nature boy
blk 89/red 91 XJ Limited
I like turtles
what else have you tried? whats is your fuel pressure at now?
1988 Mustang 5.0 LX
12.48@118.27
IDK I feel like its a little higher. If i change to a BBK 255 lph fuel pump do you think it will fix it
i doubt its the fuel pump causing the idle issue. did you change the filter while you were at it? how does it run otherwise? WOT?
1988 Mustang 5.0 LX
12.48@118.27
I changed the filter before I changed the fuel pump the car would surge violently only when the engine warms up then when I changed the fuel pump the car slighly fixed the surge it still surges but not as bad
1992 Lx
11.39@119.24
did you put your fuel filter in backwards?
that's what I was thinking..
weeee foooord!
1988 Mustang 5.0 LX
12.48@118.27
no its the right way
1988 Mustang 5.0 LX
12.48@118.27
1988 Mustang 5.0 LX
12.48@118.27
I feel like the fuel pump is for 4 cylinder cars like the escort taurus and the focus so it doesn't put out enough pressure and when I pulled out my walbro I compared them both and I see the carter fuel pump has a smaller port on it than the walbro
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/134821-idle-surge-after-fuel-pump-change.html
| Surges Fuel Pump on Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | September 11th, 2009 02:22 AM | |
Threads Similar to: Idle surge after fuel pump change
| Mustang idle surge and base idle reset | 1slo5.0 | 5.0 Mustangs | 47 | July 26th, 2011 10:52 PM |
| Had to change the fuel pump finally. | ujslost | 5.0 Mustangs | 0 | July 8th, 2008 11:10 PM |
| fuel pump change on 89 RS | DeMello | All Other Vehicles | 0 | June 28th, 2008 11:30 AM |
| Idle surge | izze01 | 5.0 Mustangs | 1 | July 1st, 2007 01:32 AM |
| idle surge | slow98gt | 96-98 | 8 | February 12th, 2007 03:56 PM |
