Window motor or..?
Old August 24th, 2009, 10:41 PM   #1
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
Window motor or..?
I get power to the last plug before window motor on pass. side. (2 wires one yellow one red) I used a test light and the switch does function but the window wont move, then ill try again and sometimes it will go up and down and sometimes it wont.
I am just wondering what everyone thinks? Or if any ideas?
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old August 24th, 2009, 10:48 PM   #2
94bonestocker's Avatar
1983 LX Hatch
94bonestocker is on a distinguished road
Window motor. The Brushes are worn. You can take the motor apart and try cleaning it and more than likely it will work for a little while longer but I'd bet $20 the brushes are about worn out.
Just your everyday Non-5.0L LX Fox
Old August 24th, 2009, 10:55 PM   #3
carnut59's Avatar
2001 gt
carnut59 is on a distinguished road
bad motor
Old August 24th, 2009, 10:55 PM   #4
aka Nature boy
sickfox's Avatar
I like turtles
Ok im glad i got to the end of this, the guy before me had replaced the doors and had alarm with poppers and had the locks bypassed so you could only use remote. It was sorta a joke how many wires were cut or not hooked up correctly.
i got it all together once last week put panels on and it didnt work, so i tore it down again. little did i know it was working/not working on its own.
LOL so this time i left panels off just incase. but ill pick up a motor and swap that out, is it as easy as pulling those 3 bolts and dropping it?
www.xjor.org
Old August 25th, 2009, 12:21 AM   #5
1983 LX Hatch
I have never pulled a mustang Motor before but I gotta believe it'd be like that.
Threads Similar to: Window motor or..?
window motor front General Tech 0 July 12th, 2009 05:07 PM
02 window motor????!!! Help!!! Blitz34 99-04 10 July 8th, 2009 12:26 AM
Question About Window Motor BostonPerformance The Clubhouse 1 October 8th, 2008 12:14 PM
96 window motor fit a 95 lugthug713 94-95 1 October 26th, 2007 10:25 PM
Drivers window motor ByPopularDemand General Tech 13 September 15th, 2007 01:49 AM
