which injectors...?
Old August 25th, 2009, 11:41 PM   #1
1990 mustang GT
cobtc is on a distinguished road
which injectors...?
i'm finishing up a GT40P head swap, w/ TFS1 cam, and explorer intake. my question is which injectors should i use? my stock #19 w/ 135,000mi. or the explorer all yellow pencil type w/ 34,000mi. they both use the same plug. is one better than the other ? thanks
Old August 26th, 2009, 02:55 PM   #2
86er's Avatar
19lb injectors will be fine for it
Just a truck
Old August 26th, 2009, 02:55 PM   #3
86er's Avatar
injectors work or they dont work, clean the old ones, soak them in a cleaning solution and go about your ways
Just a truck
Old August 26th, 2009, 03:24 PM   #4
Skirt Chasing Phallus Phondler
1FastFox's Avatar
Kit Car/Ducati/Explorer
Nike Fast
1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future
I have some 24s with new caps and rings on them I will let go for cheap if your interested.
QUOTE OF THE DAY (5/25/12): “Don’t play what’s there, play what’s not there.” ‐ Miles Davis
Old August 26th, 2009, 03:24 PM   #5
1992 Lx
11.39@119.24
winner!
Old August 26th, 2009, 09:11 PM   #6
1990 mustang GT
thanks guys. i understand #19lb. are fine. my question is which ones to use. i have a set of #19 fat body's w/ 135,000mi. that came stock in the car. i also have the set of #19 pencil type that came with the 97" explorer w/ 36,000mi. they both use the EV1 2 blade connectors but are they interchangeable, spray pattern, ohms, ...ect ?
Old August 26th, 2009, 09:46 PM   #7
86er's Avatar
injectors work or dont work, just leave the ones in the car, or if you want to swap then swap.
Just a truck
Threads Similar to: which injectors...?
New injectors! HELP Chris951 5.0 Mustangs 19 December 16th, 2008 09:43 PM
24# Injectors themainman 99-04 5 April 24th, 2008 02:24 PM
