Explorer Intake & TB, Rails etc
Old August 25th, 2009, 11:52 PM   #1
1989 Mustang LX 5.0
sniperd is on a distinguished road
I bought a complete explorer upper/lower, tb, fuel rail, etc setup.
My question is, what should I use from it? Im assuming everything, but I have read the fuel rail etc cannot be used (looks in better condition then my mustangs)
Can i use the TB just the way it is? can someone sum up this swap.
Thanks in advance!
Old August 25th, 2009, 11:55 PM   #2
BadBlackGT's Avatar
13.82@100.26
BadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the rough
Thanks in advance!
I've heard of people doing this... but does this swap give you more performance or what? Do people just use them for replacement parts, or is it proven that you get gains from it?
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
Old August 25th, 2009, 11:56 PM   #3
1990 mustang GT
cobtc is on a distinguished road
use the search option for the throttle body swap. sorry but fuel rails won't work.
Old August 26th, 2009, 01:59 AM   #4
1989 Mustang LX 5.0
BadBlackGT - It's a proven gain, It's almost the same as the GT40/Cobra Intake, gives 5-15 HP I hear depending on what other mods you have done.
Old August 26th, 2009, 05:08 AM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
For the TB, you have to switch the plate that is attached to the throttle blade shaft. It's at the bottom of the TB, and is what your throttle cable attaches to. Just grind off the little tab to remove it, swap the one from your stock TB on, and give it a good tack weld.
Then the TPS from the xplorer has to be used on the new throttle body. just cut splice, sodder, and shrinktube.
Old August 26th, 2009, 10:21 AM   #6
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Stock rails on your car are fine. Even if they look crusty or not. There true beuaty is on the inside buddy.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old August 26th, 2009, 11:47 AM   #7
1989 Mustang LX 5.0
Thanks - Although a bunch of sites disagree on the TPS, they say the tab should be ground down and the stock mustang one should be used (by widening out the bolt holes on the TPS unit itself. Do you have the explorer one working on your car?
Old August 26th, 2009, 11:49 AM   #8
1989 Mustang LX 5.0
lol, Hey, can you tell me how your dealing with your crankcase pressure? Are you venting both head vent's to a catch can that's vented to atmosphere?
Old August 26th, 2009, 12:46 PM   #9
baine21225's Avatar
you can use either, i just have a breather/filter on the valve cover
Old August 26th, 2009, 01:09 PM   #10
1989 Mustang LX 5.0
Cool, thanks
Old August 26th, 2009, 02:21 PM   #11
1993 5.ohhhh
12.97 @140mph
Line from the filler neck to the tb is disconected. It blocked on the tb. And the open on the filler neck. Also have a breather on the filler neck. I was getting oil in the pipes still. I just but a breather on the filler neck. If it doesn't help I'm going to put a water seperator between the pcv and the upper intake manifold.
Old August 26th, 2009, 08:22 PM   #12
JBIGBOOTSY's Avatar
1990 LX hatch
Yes I do. THe voltage swing is fine.
Threads Similar to: Explorer Intake & TB, Rails etc
explorer intake... 1989Gt. 5.0 Mustangs 2 September 24th, 2008 06:51 PM
Explorer Intake tkwhitestang 94-95 4 March 25th, 2008 11:25 PM
explorer intake patwrecked 5.0 Mustangs 1 July 18th, 2007 06:52 AM
