battery relocation
Old August 27th, 2009, 08:17 PM   #1
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
battery relocation
i ran the wire from the fuse box to the battery in the trunk..can i have it run this way..i still have the engine harness wire connected to the fuse box as well which i believe runs over to the alternator..correct me if im wrong, cause i saw a few diagrams and they show it running strait to the alternator
Cohagan Engineering, Inc.
Old August 27th, 2009, 08:51 PM   #2
fl4321 is on a distinguished road
yes the power wire still goes to the s/s not the fuse box.
you dont need no teef to eat my beef
Old August 28th, 2009, 12:08 AM   #3
You have to run the power wire up from the battery to the starter solenoid
Old August 28th, 2009, 12:24 AM   #4
baine21225's Avatar
+1, and ground to frame
Old August 28th, 2009, 05:13 PM   #5
TKOTLARZ's Avatar
1994 GT
so just run one wire from the positive post to the starter and ground the battery to chassis and i should run a wire from the block to chassis as well to ensure a good ground,correct?
Old August 28th, 2009, 06:20 PM   #6
baine21225's Avatar
run the red wire from the positive battery terminal to the starter solenoid, not the starter, and the black wire from the negative terminal to the frame
Old August 28th, 2009, 10:17 PM   #7
95408's Avatar
1995 Cobra Convertable
95408 is on a distinguished road
Yes ground the block.
Old August 29th, 2009, 01:31 AM   #8
TKOTLARZ's Avatar
1994 GT
then how is the rest of my car gonna get power if the power is only going to the starter?
Old August 29th, 2009, 10:33 AM   #9
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
everything that gets power comes off the battery side of the solenoid. go look at the stock setup only one wire runs to the solenoid and everything runs off that.
UNLESS there are wires added aftermarket (stereo amp wiring, extra 12v, ect) then those will need to be dealt with
Old August 29th, 2009, 06:47 PM   #10
RaceRelated's Avatar
RaceRelated is on a distinguished road
there are two posts on the solonoid. One powers up all the shit for the car with battery wire connected, and the other post if for the starter. One has constant power the other has power that comes on when you hit the key hince starting your car
BOOST CAN BE FRIENDLY
Old August 29th, 2009, 06:51 PM   #11
you do need to ground the block. Quick Car sells a nice wire kit, i just bought one for my fox and wired it up the night. I also went with bigger wires for the starter and alternator. Make sure your grounds good. better ground you have on all your shit the better power your gonna get out of the power side.
Old August 29th, 2009, 08:06 PM   #12
TKOTLARZ's Avatar
1994 GT
ok..thanks for all the help
Threads Similar to: battery relocation
battery relocation Ryguy33 99-04 9 August 13th, 2009 11:39 PM
Battery Relocation njstang 99-04 4 March 16th, 2009 07:02 PM
Battery relocation itschristorres8 Audio/Video 1 November 9th, 2008 06:13 PM
Battery Relocation ThreeHonks302 5.0 Mustangs 4 February 28th, 2008 07:47 PM
battery relocation onewinner 5.0 Mustangs 13 May 29th, 2007 03:17 AM
