Discussing 302 shortblock in the 5.0 Mustangs Forum. my stang is my only car so i cant pull the engine and have work ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
302 shortblock
my stang is my only car so i cant pull the engine and have work done to my block...i wish i could though....since i cant do that, i figured i would just get a vortech kit and install that....but then i decided that if i am going to do it, then i want to do it the right way so that when it is all done, i will be happy with it. I am not looking for a certain amount of power. I just want to build a reliable engine that i can drive every day and that runs good...of course i want it to be fast, but i also dont need 500 horsepower... i dont know if i should buy a used shortblock and have the machine work done to it, or to just buy a new shortblock and put a topend kit and a 5-6 psi blower... i really dont know what to do....it's just back and forth here... i am trying to do this using as little money as possible but i dont want junk...any suggestions would be great...
o and i also thought about just putting a topend kit and a 5-6 psi blower on the block that is in my car now...i was just worried about if the bottom end would hold up or not... |
Asshole™
1990 Mustang LX
9.36@143 mph
A stock 5 liter bottom end will hold 500hp safely and often times more than that.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
Where do you live? i am in the process of having a 331 dart based motor built and am selling my current block, its all ready to go for you,
it has about 300 miles, stock block boerd to a 306, hawks racing crank and rods, clevite h-series bearings, speed pro fogred pistons, .030, balanced, dss main support system, dss 7qt oil pan, arp main and rod bolts, arp head studs, and o-ringed deck. this setup with 12psi of boost made close to 500hp at wheels on pump gas, good tune, with ported stock heads.
91 Gt Convertible RNH Perfomance 331 dart stroker w s-trim http://i31.photobucket.com/albums/c3...0/HPIM0075.jpg dart stroker with s-trim, 91 vert |
PM sent to you JOEYD0730...
would a S/C do much on a stock motor?? i was told by a guy at a mustang performance shop that my motor could only handle 5 psi safely...and that seems like a waste of money to me cuz that wouldnt give me much power...
pm sent
yes it will do fine on a stock bottom end.
#9 | |
Asshole™
1990 Mustang LX
9.36@143 mph
darrell is correct. i was running 12psi on astock bottom end with a good tune. with no problems at all.
well 500 hps on a stock bottom end is possible but will not last because stock rod bolts will begin to stretch...I run 15psi on a 302 block
and no way your seeing 500 hp on stock heads*L*
EVERYONE IS ENTITLED TO MY OPINION![]() 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter |
#12 | |
Asshole™
1990 Mustang LX
9.36@143 mph
Threads Similar to: 302 shortblock
| DSS or CHP Shortblock? | MikeyS281 | 99-04 | 12 | May 7th, 2008 07:30 PM |
| the best new shortblock?? | caintcatchmyGT | 96-98 | 7 | May 7th, 2008 04:00 PM |
| Shortblock from Fordstrokers.com any 411 | 86gt_wit_Ts | 5.0 Mustangs | 5 | July 31st, 2007 02:30 AM |
| 400$ for complete shortblock | ninedee-coupe | 5.0 Mustangs | 5 | January 15th, 2007 11:14 PM |
| stroker shortblock | 9stang1 | 5.0 Mustangs | 3 | December 13th, 2006 10:02 PM |
